Old 11-28-2005, 01:05 PM   #1
Buckman
mph when kicks into OD?
guys, what is the mph when your trucks with 700r4 kicks into OD? I adjusted mine at about 54 to 55 mph is this about right?
Buckman is offline   Reply With Quote
Old 11-28-2005, 04:25 PM   #2
Buckman
Re: mph when kicks into OD?
Anyone..
Old 11-28-2005, 04:28 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
everything I've briven is more like 45, but that is way to low IMO. As long as your cruising range is not at a point where it kicks in and out od OD, you'll be OK.
Also need to make 100% sure your line pressure is right, if it isn't...you'll have a very expensive paper weight in 20,000 miles.
Old 11-28-2005, 04:33 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My 86 kicks in between 40-45 mph...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-28-2005, 05:11 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
The 83 700R4 in my 67 kicks in at 40-45 and the one in my Z71(4L80...same difference) kicks in at about 45. If I am continuing to accelrate past about 55 mph I leave it alone, But if I'm only going 50 and under I put the shifter in D. I burned up the 700R4 in my 67 due to bad TV adjustment (I did what you did and adjusted it so it shifted later). Better of to set the cable correctly and shift it into D when necessary. I plan on going with a bowtie overdrives TV cable kit which should take the guess work out of the adjustment.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-28-2005, 07:55 PM   #6
Longhorn Man
Good idea redneck. For a nonstock aplication, that is the ONLY way to go.
Old 11-29-2005, 03:57 PM   #7
Buckman
67chevyredneck, how does a bowtie overdrive tv cable kit work and where do you get one?
Old 11-29-2005, 04:08 PM   #8
67ChevyRedneck
Go to this website:
http://bowtieoverdrives.com
You basically tell them what tranny you have and what carb you are running. I have NOT done this install myself yet, but several others along with Classic Trucks magazine (who did a tech install on one a while back) have given this kit praise. I've heard they have a good tech staff that you can call if you get stuck, but the kit comes with instructions. Basically you install their plate under your carb, hook a few odds n ends up and it's done. I think it costs around 70 bucks. Their website has some really good info on it. Spend some time there and read their FAQ's
EDIT: Here's the install article Classic Trucks did:http://www.classictrucksweb.com/tech...ble/index.html
Jesse James
Project "On a Dime"
