Old 11-28-2005, 06:24 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Removing Sunvisors
I have this really nice set of Green sunvisors I want to sell,
but I can't get the damn things off, the only thing holding
them on it the Phillips head screw, and the whole thing is
turning when I try to unscrew it, any tips, tricks, ideas
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-28-2005, 07:37 PM   #2
blazerboy72
Re: Removing Sunvisors
let me know when you are ready to sell them
blazerboy72 is offline   Reply With Quote
Old 11-28-2005, 07:51 PM   #3
Huck
Huck's Avatar
If your talking about the visor brackets on a blazer, the backing spring nut is probably rusted off and turning with the screw. If you try and pry on the bracket while turning, you might get lucky--otherwise you will probably have to drill out/off the head of the screw.
Huck is offline   Reply With Quote
Old 11-28-2005, 08:09 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I tried the pry with force while using a screwdriver method, didn't get lucky
Next step will be drilling unless someone adds another tip / trick to the list.
Old 11-28-2005, 08:15 PM   #5
blazerboy72
I just need the brackets anyway so the small tears dont mater
Old 11-29-2005, 12:32 AM   #6
69TowRig
Well if you don't get them off I have a pair that I need to get rid of. I haven't looked at them close enough to know what kind of condition they are in.
No clue how to get them out if the nuts came loose.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-29-2005, 10:12 AM   #7
Dan72cst
Dan72cst's Avatar
Blazer visors have a bolt that goes through them to hold the top on????
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 11-29-2005, 01:07 PM   #8
vtblazer
vtblazer's Avatar
I've had the same issue...
My cure/fix was to use an air gun.
By "blipping" the trigger the start up revolutions from the gun eventually manage to loosen the nut/turn out the bolt.
Worked for me anyway, good luck.
Try soaking your nuts for awhile with PB Blaster or similar...
vtblazer is offline   Reply With Quote
Old 11-29-2005, 01:11 PM   #9
70rs/ss
70rs/ss's Avatar
You said soak your nuts he he he, shut up Beavis!!
70rs/ss is offline   Reply With Quote
Old 11-29-2005, 05:47 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
