Gas mig wire?
What size mig wire should I use for doing my cab corners, rockers, and floor pans? Also, how much will I need? I'll be using gas, not flux cored. Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
![]() Join Date: Mar 2004
Re: Gas mig wire?
.23
btw you should have probably asked in the paint and body board but no biggie good luck with your repairs and practice first on scrap. ondrew |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Gas mig wire?
I use .30 in my little miller matic... Seems to work pretty good..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Gas mig wire?
I started out with the .23 but couldn't hardly see the wire so I switched to the .30 and was alot better for me.Of course I am blind in 1 eye and can't see out the other 1
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Project92 SWB stepside
Re: Gas mig wire?
I also use .30 in my Hobart 210. Works great.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
![]() Join Date: Feb 2003
Re: Gas mig wire?
You might rather use .023 easy grind wire. .23 wire is almost 1/4 inch thick.....Z
Fabricate till you "puke"
Re: Gas mig wire?
I would go . 023-.025 on the wire on the tin.....I run .035 on the 200 amp lincoln, & while it can be turned down to do the tin, the old sp100 does a decent job on the lite stuff. Best of luck.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: Gas mig wire?
i knew someone would catch that. lol
Re: Gas mig wire?
i'd use .025" for body work.
'72 lwb pickup daily driver |
Re: Gas mig wire?
Thanks for the help guys! Since I'm new at welding, I'll try somewhere in the .023-.025 range, as the less grinding after the better.
Re: Gas mig wire?
I use the .023 from home depot in a 2lb roll in my little Lincoln. The .030 works good too, the .023 is just a little better for sheet metal.
Mike |
![]() Join Date: Aug 2005
Re: Gas mig wire?
Glad I read this. I just picked up some .035 and it's burnin holes at the lowest juice setting. I've been using .030 before this spool. Now I'll have to try .025. Thanks guys.
