Old 11-28-2005, 08:37 PM   #1
poink 71 chev
Help with smoking
Diagnose this one......
Hey all, i need a little help figuring this one out.My 71 w/ 350 700r4 and edelbrock performer intake/carb,recently developed a problem. It appears to have a small miss and rattle. started smoking out both sides.( a white smoke w/ no obvious odor.) When you idle it up, it smoothes out, and sometimes quits smoking completely. The motor has 2000 max on the rebuild,and did fine til now.....I pulled the covers, rocker arms and push rods ok. All valves appear to open and close normally.........any help?
If you cant laugh at yourself,....at least let me do it!
poink 71 chev is offline   Reply With Quote
Old 11-28-2005, 09:57 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Help with smoking
Hows the oil look is it milky???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-28-2005, 10:27 PM   #3
poink 71 chev
no, the oil looks brand new. I also just tested the coolant,and it was full,no bubbling on warm up.......i am kinda leaning towards possible atf for the smoke.
Old 11-28-2005, 10:45 PM   #4
truckdude239
truckdude239's Avatar
bad mod vavle on side of trans it sucking fuild back and burning it off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-28-2005, 11:06 PM   #5
poink 71 chev
does the 700r4 have the modulator mounted on the side like a th350? Ive seen them suck a tranny dry thru the diaphragm....Been awhile since ive looked at a 700r4.
Old 11-29-2005, 12:23 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
No mod valve on the overdrives
You may have a leak on the intake gasket and gettin some coolant into the cylinders.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
