A/N fitting question
Can someone tell me what the A/N equilavent would be to a 1/2 inch hose. I'm running -8 from my regulator to my carb. Not sure if the -6 or the -10 is bigger. I'm running 1/2 hose from my fuel cell to the regulator.
Re: A/N fitting question
not sure of the 1/2" equivavent but the -6 is smaller than -10. I know for sure.
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
Fabricate till you "puke"
If memory is with me , I had to reduce to #6 from #8 on the cell to go 3/8 line.......Im pretty sure 10 is the next size bigger than your 8 (dont play with an fittings too much tho)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 11-28-2005 at 08:54 PM. |
I believe AN fittings are baised on #16 being "1. #8 would be 1/2",#6 =3/8",#12=3/4". Chris
Make a fraction of the numbers to do the convertion. An # as the numerator and 16 as the denominator. 8(an)/16 then reduce it to lowest terms and you get 1/2". works with them all
Brandon project 67 swb bagged on 20" Coddingtons |
#6 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#7 | |
Thank you!! |
