Old 07-11-2002, 03:46 PM   #1
GMC_Aaron
Tranny/Posi combo
I have a 1972 GMC Super Custom truck that is basically stock and I want to put in a tranny with over drive. I would also like to put in a posi rear end. I have TH400 now, but I want overdrive because I go on some long trips every now and then and I would like to have overdrive. Posi can speak for itself. What would be a good setup? Any ideas would be helpful.
Aaron
Ventura, Ca.
1972 GMC Super Custom SB350/TH400
GMC_Aaron is offline   Reply With Quote
Old 07-11-2002, 03:53 PM   #2
slam33
slam33's Avatar
Big or small block ? You can go for an all in one like a 700r4 but I'm not sure how it would handle a BB, maybe yes maybe not so yes. Or you can go with an aftermarket add on like a Gear Vendor, with a BB yes it can handle it. Your going to be looking for a non- computer controled unit.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 07-11-2002, 04:05 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
what kinda engine do you have?
With a vette servo and a hardend sunshell ,pump mod,and shift kit on a newer 700r4 can take up to about 500 hp without slicks pretty easy.
But it would be wise to get a gear vendors under/overdrive unit and bolt it up to your th400.
Those things can handle 1,200 hp out of the box!
Either way it is going to cost a little to get a good overdrive unless you have a good hookup with a local bone yard/trans shop.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-11-2002, 06:13 PM   #4
Mike C
Mike C's Avatar
TH700 and 4.10 gears if you are running a 30" tire (like 265 75 16) or 3.73 if runnin a 28" tire. The 700 should be fine as a new Vortec 350 makes as much torque as a mostly stock truck 402. Figure on spending at LEAST $1000 dollars and shop around for a rebuilder with a GOOD rep for 700's as they are more finicky than a TH350/400. The gear Vendors will set you back $2000 in addition to the fact your 400 probably could use a rebuild anyways.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-11-2002, 08:23 PM   #5
GMC_Aaron
I have a small block 350.
Aaron
Ventura, Ca.
Old 07-11-2002, 11:09 PM   #6
Custom 68
Custom 68's Avatar
Question gear vendors
What the heck are you guys talking about? What is this thing you bolt to your 400 turbo to make it an overdrive? Is there a site with more info on them? or am I misunderstanding what you mean.
Well ok I guess I should have looked around before asking. I had just never heard of them. Here is a link I hope
http://www.findarticles.com/cf_offrd.../article.jhtml
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-11-2002, 11:27 PM   #7
frogsmakr
frogsmakr's Avatar
try www.gearvendors.com
frogsmakr is offline   Reply With Quote
