Questionable
Need high hump help
Seems to be a popular topic lately.
I'm going to be cutting out my low hump and finishing the bolt-up for my tranny this week. I was curious if anyone could give some pictures of: 1) A stock high hump floor that's bolted in. 2) A stock high hump floor with the hump removed. 3) Maybe give a picture showing how much overlap there is.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Questionable
Re: Need high hump help
PS - I already have the high hump replacement from an AT truck.
fugedaboutit
![]() Join Date: Mar 2005
This is all I have right now but could snap a couple shots when I get home from work..
http://i7.photobucket.com/albums/y25...nandrocker.jpg http://i7.photobucket.com/albums/y25...ad69/dash3.jpg http://i7.photobucket.com/albums/y25...nandrocker.jpg
Currently truckless ![]() |
God Bless Mr. T
Here's a pic of my high hump. It's in perfect shape and is shiny and rust free. I just wish I could say the same thing for the rest of my floor!
Like a midget at a urinal...sometimes you must stay on your toes. Last edited by JameslovesJammie; 11-29-2005 at 06:41 PM. |
Questionable
James - thanks - that's a great picture (i'll stick it to my post). redhead - thanks to you also, I'd like a closer shot of the hump when its off if you got one. I'm open to seeing more pictures if anyone has em.
Thanks a ton
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-29-2005 at 06:35 PM. |
Shifty - If you have your high hump piece already, position it in place-side to side even and in the forward location. Use a felt permenant marker to outline the edges and the holes. Remove the high hump and sketch out the inside edge. Use slip on nuts(j-nuts or something like that - Lowes carries them) to fasten the high hump down. Cut the hole smaller at first and then enlarge it as needed.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Car O'Holic
quck question for redhead69 do the new floor pieces come with the studs for the gas pedel and the holes for the high/low switch?
#8 | |
fugedaboutit
Post Whore
![]() Join Date: Feb 2000
Shifty - here are a bunch of pics I took when I was swapping my high hump for a low hump. I have a body lift that allowed me to do the swap to the low hump in my 69 K20. I may have posted some of these before but I figure more is better than less.
Here are a few pics of the stock high hump ![]() ![]() Here is the floor with the hump removed to see how much overlap there is ![]() ![]() ![]() Ignore the wierd shifter extension - that has gone away ![]() Here are a couple pics of the low hump installed ![]() ![]() ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Questionable
Bob - thanks for the advice.
Yukon - thanks for the pictures. Based on the pictures, looks like your low hump was welded to the floor originally? Perfect - this is my exact setup (think your pics are backwards in progression though ![]()
Post Whore
The low hump came from a boardmember who had a junk cab. He used a torch probably to cut it out. I have never worked with a low hump cab before so I don't know if the low hump is stamped from the floor or is welded in normally. I think what I did is the reverse of what you are doing. I had a high hump cab in my 4wd and I changed it to a low hump - I did this so I wouldn't have to modify my transfer case shifter due to my body lift. I didn't have to modify my floor at all - that is the way a stock high hump floor is - at least in a 4wd. Hope this answers your questions.
Questionable
Yeah, that answered everything!
I'm not sure how much of a lip I'll have on the floor. Should be pretty interesting weekend getting all this done.
