Old 11-29-2005, 03:38 PM   #1
BudTX
BudTX's Avatar
Newby question - Window seal?
The driver's side window seal on my 83 K20 is deteriorated, and I don't want rain and snow dripping down into the door and causing rust.
How do I remove and replace this rubber seal? Do I have to take the door apart? Where can I find replacement seals?
Thank you,
Bud
Current GM toys: 1983 Chevrolet K20 4x4, 2004.5 Chevrolet 2500HD LT Duramax 4x4
BudTX is offline   Reply With Quote
Old 11-29-2005, 05:01 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Newby question - Window seal?
The seal that run around the glass? You have to remove the glass from the channel to get it in there.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-29-2005, 05:37 PM   #3
BudTX
BudTX's Avatar
I'm probably not describing it right, but it is the rubber seal that rests against the bottom of the outside of the driver's window. It looks like the previous owner drove around with the window down, resting his arm on the door and the rubber wore out.
Old 11-29-2005, 08:56 PM   #4
84 400
Sb 400 club
84 400's Avatar
ahhh yes i need a new one too. with the window dow you can get them off they use little clips. The replacement is avalible from chevy, lmc truck.com , and chevy duty.com, and jc whitney.com. good luck yeha mine needs that as well as all the vent window seals replaced
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-30-2005, 09:43 AM   #5
BudTX
BudTX's Avatar
Thanks for the sources.
My vent windows whistled badly, so I used clear silicone caulk around the outside to seal that up. I plan on cutting through the silicone with a razor blade to allow use of the vent come summer.
Old 11-30-2005, 12:27 PM   #6
Captkaos
Captkaos's Avatar
I sell all those seals also. I just haven't added them to the catalog yet. Another source is the Dealership.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-30-2005, 03:44 PM   #7
ureckme
ureckmefixit2@cox.net
It's called a belt molding/seal get it a the dealer
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
