Old 11-30-2005, 01:12 AM   #1
RED71CHEVY
RED71CHEVY's Avatar
rear brake bulb.......
i have installed new led 1157 bulbs, and now only one light is on,it is super bright.buit only one lights up when lights are on, both come when brake is pressed, both are on when using flashers,,,,,,,, but only one is lit when lights are on.......i am so confuuuuusssseeeddd ..help, explain, tell me how to fix it,,,,do i need more parts or what!!!!
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 11-30-2005, 07:47 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: rear brake bulb.......
I believe you may have the bulb in wrong, pull the problem bulb out and make sure you didn't get it in there wrong? look at the tabs on the bulb to make sure you are getting it in there correctly.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-30-2005, 08:19 AM   #3
Smitty
Smitty's Avatar
Bulb is probably bad. Tail lights function on one fillament and the brake/turnsignal on the other. Try it on the side that works. That should confirm it!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 11-30-2005, 08:41 AM   #4
truckdude239
truckdude239's Avatar
what they said
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
