Old 11-30-2005, 08:09 PM   #1
76bonanza
76bonanza's Avatar
ralley wheels
I was looking in the CPP catalog will those 3 inch deep trim rings fit on all ralley rims? Also those baby moon centers will they fit on any ralley if you remove the other center cap?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-30-2005, 09:46 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: ralley wheels
I think the 3" ring only fits the 8" wide version. Not sure about the baby moons.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-30-2005, 09:50 PM   #3
76bonanza
76bonanza's Avatar
Re: ralley wheels
I think I have 15x8 so they should fit.
1968 c10
lowered 3" 4"
Old 11-30-2005, 10:14 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Re: ralley wheels
An 8" rim actually measures 9 1/4" lip to lip
Jim
Old 11-30-2005, 10:22 PM   #5
76bonanza
76bonanza's Avatar
Re: ralley wheels
so will it fit 15x8 rims or not? I am confused now.
1968 c10
lowered 3" 4"
Old 11-30-2005, 10:25 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Re: ralley wheels
If you have the wide version of the rally which you probably do, then it will work.
Jim
Old 11-30-2005, 11:27 PM   #7
dennislbrooks
dennislbrooks's Avatar
Re: ralley wheels
Just me probably and may depend on the type of ring, but I have 15x8 vette ralleys on my 67 and I did not like the appearance of the 3" rings. Covered up nearly everything. I now run like 2.5 or so. If possible you might try various depths before you buy if allowed.
dennislbrooks is offline   Reply With Quote
Old 12-01-2005, 07:56 PM   #8
76bonanza
76bonanza's Avatar
Re: ralley wheels
dennis what is the differance between the vette and regular rallyes? Also in that pic is that the 2.5 inch ones? Mine now cover none of the inside lip(from stem in) My inside lip(for lack of a better term) is like 3 inches wide will center caps like you have fit on all rallye rims? Thanks for your help.
1968 c10
lowered 3" 4"
Old 12-01-2005, 09:59 PM   #9
dennislbrooks
Re: ralley wheels
76Bonanza, I beleive if you have chevy truck 6 or 5 lug ralleys that the oem stainless rings are about 2.5" and I think the inside lip lays flatter on the inside of the rim. I was disappointed in my aftermarket 3" stainless rims because they are more cone-like and give the appearance of a smaller center in the wheel.
The 2.5 " ones I have now really do not suit me either. I wish I had the chevy 6 lug 4wd drive oem rings like was on one of my previous vehicles as in the 2nd pic below.
The pic below is one of my 3" aftermarket rings which is still new along with the other 3 still in the box.
Old 12-01-2005, 10:01 PM   #10
dennislbrooks
Re: ralley wheels
Also, I do not think my disc brake center caps will fit on the oem truck ralleys.
Old 12-01-2005, 10:16 PM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: ralley wheels
12" Ralley rim with factory 4x4 rings and caps......M2C
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-01-2005, 10:26 PM   #12
dennislbrooks
Re: ralley wheels
kelsfine69 -- how much back spacing are on your 12" ralleys? Do your tires come close to hitting the fender lips? Are they corvette style ralleys? If Corvette style where did you get them?
Old 12-01-2005, 10:27 PM   #13
76bonanza
76bonanza's Avatar
Re: ralley wheels
dennis my centers are like your 4x4 but my trim rings do not pass the valve stems. Do you you know if any of the after market centers that cover the lugs will fit the oem rims?
1968 c10
lowered 3" 4"
Old 12-01-2005, 10:44 PM   #14
dennislbrooks
Re: ralley wheels
Someone that has oem truck ralleys may know for sure. Your rim center cap probably is either held in place by the lug nuts or with 3 self tapping bolts. I have not seen a center cap for them that entirely covers the lug nuts.
Old 12-01-2005, 10:45 PM   #15
Boog
laying low
Boog's Avatar
Re: ralley wheels
76. The stock caps for your truck rallys are bolted on to the wheel. There are no bumps around the center for a moon type of cap to attach by. One option I've thought about is using the 88 up truck rally center cap on the older truck rally wheel. They just snap over the actual lug nuts and give the wheel just a little bit different look. I wish I had a pic to show you.
Also, have you been through the very first sticky at the top of the page yet? It's all about wheels n tires. Lots of good pics there. May help you.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-01-2005, 11:03 PM   #16
409biscayne
409biscayne's Avatar
Re: ralley wheels
I believe y'all are talking about 2 different style rims / centers , although they may be made to fit trucks . The truck ralley's have bolt on center caps and as far as i know will not accept a Corvette style center . The trim rings work on either rim , IMO the truck style look better on 67-72 than the flatter Vette style . You can usually find the the truck trim rings if you visit enough wrecking yards , check on Suburbans & Vans . The originals are still available , but expensive .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 12-01-2005, 11:25 PM   #17
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: ralley wheels
They still have the factory backspacing. I cut the rim in half and added 3" to the outside and welded it back together. No they dont rub.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 12-01-2005, 11:28 PM   #18
chopped 71
Re: ralley wheels
I HAVE VERY SMALL RING'S SO YOU CAME SEE MORE OF THE RIME.
chopped 71 is offline   Reply With Quote
Old 12-01-2005, 11:58 PM   #19
76bonanza
76bonanza's Avatar
Re: ralley wheels
chopped those are the corvette rims? That is the size trim rings I have and want to try larger ones to show less rim. Was hoping I could use those centers like yours but that looks like it is not going to be possible.
1968 c10
lowered 3" 4"
Old 12-02-2005, 01:32 AM   #20
409biscayne
Re: ralley wheels
It is possible , it just costs more . My buddy has a set of 15x8 and 15x10 six lug Corvette style ralley wheels with the small cap that covers the lugs , like the earlier post. These were mounted on a 68 c10 that he sold. May be available .
Can-Am Motorsports
Old 12-02-2005, 03:10 AM   #21
67shortie
Green club
67shortie's Avatar
Re: ralley wheels
I have the exact same wheel/center/trim ring as chopped. It looks great on early bodystyles
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 12-02-2005, 03:19 AM   #22
BigMike
BigMike's Avatar
Re: ralley wheels
I picked mine up a while back for $200 for the set of 4 corvette rallies. I have 7" for the front and 10" in the rear. I was unsure if I liked them at first, at least on our trucks, until I saw a pretty sweet truck with these on it. The guy I got them from has most sizes available, 6", 7", 8" and 10".
Mike
BigMike is offline   Reply With Quote
