Old 11-30-2005, 11:51 PM   #1
redneckdds
redneckdds's Avatar
where do I start?
I need some help on finding a truck for my needs and from a financial standpoint... do I spend more for a truck with a good body to start with or pay peanuts for crap and pay the coin to have body work done? another question... do I go for a truck with all the options on it, working or not? I was thinking at least I can find replacement parts.... or should I go bone stock and add what I want, ie. a/c, ps/pb/at, etc??? same question about the motor and tranny.... do I want the turbo 350/400 it came with and rebuild it or look for a truck w/a stock v6 and toss it with a newer tranny 700r4, etc??? I need some help, I am stuck. I want a very straight, clean, fast truck, with the option of throwing a supercharger or n20 on it, later on. hope my questions are clear.
redneckdds is offline   Reply With Quote
Old 11-30-2005, 11:55 PM   #2
FormerMember
Re: where do I start?
Depends on your skill set.
I hate body work and I suck at it. So I would go for a mint body and replace all mechanical components.
As for the rest, I am pretty mechanically inclined, so I can add my own stuff. I also want to customize my truck, so I went for a no-options one.
Depends on what you're going for.
FormerMember is offline   Reply With Quote
Old 12-01-2005, 12:04 AM   #3
krue
Designated A-hole!
krue's Avatar
For the most part you should buy a truck in the best shape you can afford. And as mentioned above, if you have to compromise, then play to your strengths.
Biggest thing is don't get in a hurry, take your time and shop around.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-01-2005, 12:05 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Paint and body is THE most expensive aspect of a classic...at least in my part of the country. I think the rust buckets in AZ just need a cab corner and a rocker to be mint, so you'll way ahead in the game from the get go.
Old 12-01-2005, 12:05 AM   #5
redneckdds
redneckdds's Avatar
probably have others do a majority of the work... you think I am lookin at a mint?
Old 12-01-2005, 12:31 AM   #6
muddpile
muddpile's Avatar
I bought a rust bucket with a new tranny, and rebuilt engine/rear end. Why, you ask? Because I'm not that mechanically talented, but I can sand and paint pretty well, and welding doesn't seem that hard. If you are hiring EVERYTHING done, however, a truck could bankrupt you. It would probably be in your best interest to buy a nice one, just my opinion as some parts can be pretty pricey, not to mention labour.
muddpile is offline   Reply With Quote
Old 12-01-2005, 07:27 AM   #7
HeavyD
HeavyD's Avatar
I strongly encourage you get the best body you can find, as that is the most expensive part by far. Considering where you live, finding a nice clean example to start with shouldn't be too hard. Any drivetrain can be added to these trucks, but it is a little easier if the desired combo is already installed..just means less parts to search for. I have found options (with the exception of A/C) easy to get and add, so that is not a problem unless you need to have some weird one like a record player/tissue dispenser/electric toothbrush. Tilts, buckets, tachs, etc..are always for sale on the board, so building a truck the way you like it will just require some dedicated scanning of the parts for sale section.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 12-01-2005, 10:35 AM   #8
VinceY
Just need a couple more parts.
VinceY's Avatar
Do you want to drive it now or in 2 years?
If you can wait for a couple years then fix it up exactly as you want, although paying others to do most of the work will most likely run you more than buying something that is close to what you want.
If you want to drive it now, there is always someone out there who has done all the work and spent a bunch that has to sell for less than they have into the truck.
You live in a great area for good solid trucks whether they are finished or need finishing.
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 12-01-2005, 01:10 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Like the others said, get the best body you can for the money you have. The mechanicals are easily interchangeable and usually upgraded while in your ownership.
Where you live, makes a difference in what you have available. In Gilbert, AZ, you should be able to find a decent body. Back in '70, I bought a '38 GMC, in Tucson. The body was solid.....no rust whatsoever. The engine was history (a Pontiac flathead six). The tires were weathered, to say the least, but all were up, or so I thought. Turns out the tires were almost petrified. Only one of them had any air in it. The rear had 8-ply tires and they were absolutely solid.....with no air in them. All of this info is just fluff, though.
So, how much money do you want to spend, or how much do you have available? If you think you know how much you will have to spend to buy, fix and upgrade your new toy, may I suggest that you consider quadruppling the amount you have in mind? It seems that doing that, will let you know how much to tell, or not tell, your bride....if you have one. If not, you'll know that it ain't gonna be a cheap as you first thought.
I have heard that old cars (and trucks) are like "holes in the air, into which we continually pour money". Boy, I didn't know how true that was. But, it's addictive and we welcome all those who are afflicted!!
Member Nr. 2770
Old 12-01-2005, 06:38 PM   #10
junkyarddog1956
junkyarddog1956's Avatar
Wish you wasn't so far away ... the truck in my avatar is for sale ...ready to be reassembled ... Joe
69 Chev C-10 ... painted and ready to reassemble ( for sale )
82 Custom Deluxe ( have parts to restore )
junkyarddog1956 is offline   Reply With Quote
Old 12-01-2005, 06:42 PM   #11
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
A lot of what your asking is personnal preference ,based on your skills.
I suck at body work and paint , so I would go with the best body I could aford ( as most have mentioned )
I would also try to get as many options as possible ( PS,PB Tilt,Ac,Disk brakes) . You will find that it is time consuming and expensive to add them later .
I would also look for a Small Block as parts are plentiful and inexpensive .
on a final note BEWARE hanging around here will give you the bug to make a daily driver rust bucket a truck you have to park 1/4 mile from everyone else so not to get any door dings .
Before and After 4 years here .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-01-2005, 06:49 PM   #12
paintpyro
paintpyro's Avatar
hmmmm, Shiny!
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 12-01-2005, 07:50 PM   #13
bad68bowtie
On the college boy budget...
bad68bowtie's Avatar
Payin other people gets real expensive real fast, bein only 17 I work with limited knowledge, experience, tools and space and I never intended on spendin as much as I have on my truck as quickly as I have, luckily for me my parents take most of the financial burden. You can spend a good deal of money buyin parts alone, but factor labor into that and your costs will go through the roof. A lot of it does depend on how nice you want it to be, how often you'll drive it and all of the other things that have already been said here. I'd agree with playin to your strengths and skills, definitely look at a lot of trucks and wait for the right one to come along.
-'68 C10 short/step- 350/350
bad68bowtie is offline   Reply With Quote
Old 12-01-2005, 08:37 PM   #14
DangerBoy
You could always go my way and buy a dented up bucket of bolts with a crap engine and learn a ton doing engine/tranny/rear end/body/ and any other work concievable on it.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
