Old 12-01-2005, 01:53 AM   #1
69-350
Oil trash and damn proud of it
69-350's Avatar
mounting alternator
well, the other day on a trip to my friend's house only a couple miles away, when I went to fire her up to get back home, battery was dead. So I called a bud up and we jumped my battery, and figured out my alternator wasn't spinning. Anyways, so I crack the ONE BOLT that holds it on the bracket, and as I'm tightening it to make sure it doesn't wiggle loose again and slip the belt like it just had, I snapped the head of the bolt off. oh crap. then my buddy's folks show up, and his dad makes a trip to the hardware store and buys me a nice long bolt. problem fixed.
Which leads me to my question. How should the alternator be held up? Shouldn't it be more than one bolt? I think my 350 came out of a mid-80's, and the bracket for the alternator doesn't look too grand. It's held on tight enough by I think two bolts, and the alternator alternatly is held on by one bolt through the large slider slot in that bracket. Isn't the dang thing suppost to be held up by another bracket or something? Maybe some explanation or pictures would help me out here, if you have any of your alternator mounting. Thanks, Mark.
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 12-01-2005, 11:14 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: mounting alternator
Typically on a Passenger side mounted alt, there is a triangle bracket off the water pump and a spacer with a long bolt that runs though the bottom of the alt.This holds the alt and allows it to pivot.At top there is a bolt that runs in the slide bracket to tension the belt.
sneakysnake is offline   Reply With Quote
Old 12-01-2005, 12:15 PM   #3
truckdude239
truckdude239's Avatar
umm is that your batery cable grounded to the alt braket?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-01-2005, 07:41 PM   #4
69-350
69-350's Avatar
yeah, that is my battery's negative cable, grounding it out there. Why? I guess that isn't the best place to have it?
and I guess I do have that thin long bracket somewhere, if I'm not mistaken, I think I found it in the box of my truck when I bought it. I'll have to go brave the 10 degree weather and see how that goes. thanks.
Mark
