Old 12-01-2005, 09:12 AM   #1
Kustom
blower will not stop running
The blower motor in my blazer will not turn off. Even with the truck off the blower keeps running. Just started doing it this morning. What could cause this? Thanks in advance
1969 Chevy LWB 350, vortec heads, pro perf intake & powerglide
1985 Chevy K5 Blazer
1951 Buick 2 door HT; 350/350 combo, sub frame, disc brakes
Kustom is offline   Reply With Quote
Old 12-01-2005, 07:30 PM   #2
86 GMG
Re: blower will not stop running
?????????? But My First Thing I Would Look At Would Be The Relay On The Side Of The Fiber Glass A\c Box Under The Hood Best Wishes!
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 12-02-2005, 10:19 AM   #3
Kustom
Thank you for the reply. I put a new relay on last night and that fixed the issue. Thanks again.
Old 12-02-2005, 11:17 AM   #4
86 GMG
great will you come fix mine now my motot dont run at all the relay i bad but still the fan dont work so in to the dash i go this weekend
Old 12-02-2005, 11:25 AM   #5
crawdad
crawdad's Avatar
Are the fan motors suppose to run on a low speed all of the time? Mine runs constantly on a low speed even when the switch is turned off. Another thing that is screwey is that the AC compressor wants to keep cutting on and off on all settings except "heat" and "vent", even in the off position. I wonder if the relay could also be causing these problems?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 12-02-2005, 01:50 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
When mine did that it was a burned wire going to the fan. I think it was a heavy purple wire. I still don't know WHY it burned the wire, and it never popped the fuse, but disassembling and cleaning the connector fixed it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-02-2005, 01:56 PM   #7
Slonaker
Slonaker's Avatar
Regarding the fan running all the time...it has been said on here before that the trucks are supposed to do that to provide ventilation to the cab. As nearly as I can tell, mine does not run all the time. I have only seen people with older trucks ask the question, so that may or may not be a factor (mine's an '86).
My compressor comes on any time I run anything except heat. Someone on here several months ago said that they fixed that problem by replacing the dash controls for the heat and a/c. I bought the controls, but have not yet replaced them. I got genuine AC Delco replacement parts from a store that carries them locally, and the whole unit was less than $50.
Slonaker
Stock '01 Silverado
Old 12-02-2005, 05:08 PM   #8
86 GMG
i have checked the power wire at the switch and no power but have power to fan if i jump the orange wire to a power sorce i must have a bad connection somewhere i am going to call a buddy that works on vehicles everyday unlike me and maybe i will have heat to work monday, wont it be nice to take off the long johns
Old 12-03-2005, 11:53 PM   #9
TrainD5115
North Coast, baby!
TrainD5115's Avatar
My fan runs at low speed when truck is running. As far as blowing relays goes, I had trouble with my idle compensator solenoid lead grounding out by the carb and blowing the fan relay. If you have one you should check it out for same problem.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-05-2005, 09:59 AM   #10
86 GMG
thanks
