12-01-2005, 11:54 AM | #1 |
Old air fans
anyone use the old air products dual electric fan setup? Is it really a direct bolt on? and how do you like it?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
12-01-2005, 12:04 PM | #2 |
Questionable
Re: Old air fans
I've never used it, but I've found that the LS1/LT1 dual fan setup is a direct bolt-on for my radiator. I think mine specifically is out of a 94-96 LT1 maybe? It's the one that allows you to actually replace a single fan easily should the thing go bad. I picked up my fan setup from FBodyChopShop for under $100 shipped. Tony was a true pleasure to deal with ( www.fbodychopshop.com )
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 12-01-2005 at 12:06 PM. |
12-01-2005, 12:59 PM | #3 |
Re: Old air fans
here is a link to it
http://www.oldairproducts.com/shop/a...d82d8c022432d4
12-01-2005, 07:25 PM | #4 |
Re: Old air fans
This is such a slick setup I can not believe no one else is using it? Is there soemthing wrong with it?
12-02-2005, 05:10 PM | #5 |
Re: Old air fans
no one? now I am scared to use it.
12-02-2005, 05:48 PM | #6 |
Re: Old air fans
It's EXPENSIVE.
We are all cheep (I speak for myself) Seeing that a 16" fan can be had for under $100 and cool's fine with some custom brackets.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-02-2005, 06:07 PM | #7 | |
Fabricate till you "puke"
Re: Old air fans
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-02-2005, 07:21 PM | #8 |
Re: Old air fans
Well I want a clean stock looking install and I like the fact it has duals fans and the way they run one always on, one with thermo switch. I dont want to say money does not matter but I really like the looks and ease of install other than the cost you guys think it would work ok. I value your opinion.
12-02-2005, 07:51 PM | #9 |
Re: Old air fans
I have one of the Old Air setups on my 72 GMC 3/4 ton 4x4. It is a very nice unit and works like it's supposed to, BUT -- It is not keeping my 454 cool even in 35-40 degree temperatures. Summer/Winter it keeps my engine at about 200-210 degrees. That's with a 180 degree thermostat and NEW radiator. I am not blaming the unit, there could be another problem. Two other issues to consider are the noise it makes (I don't have all the sealing foam in -- could make a difference), and the amp draw. I have a 100 amp alternator and it takes all of the alternator to run the fans/heater/headlights/wipers. This is Oregon after all. If you have any questions, maybe I can answer them.
72 GMC K20, 454, TH350 00 GMC Yukon 66 Ford Bronco |
12-02-2005, 08:05 PM | #10 |
Re: Old air fans
What kind of noise does it make? Have you ever checked to see how many amps it draws with both fans going?
12-02-2005, 08:06 PM | #11 |
Re: Old air fans
I am looking for something with dual fans that bolts right in and has all wiring and stuff does anyone else sell a unit like that?
12-02-2005, 08:18 PM | #12 |
Re: Old air fans
I asked their tech support about amp draw and they claimed 57 amps.
It sounds like a big blower while sitting at a stoplight. Sometimes I get looks like there is a turbine under the hood. I originally had their foam gaskets installed, but the fans sucked them in and thru the blades. I am now looking for tougher foam. The fact that there's a 1-2 inch gap around the shroud may be causing my overheat problem, but I really think there's an engine issue causing it, since it happens in all weather.
12-02-2005, 08:25 PM | #13 |
Re: Old air fans
57 amps holy crap that seems like a ton.
12-03-2005, 09:07 AM | #14 |
Re: Old air fans
I have the Old Air fan set up. It is a bolt in and keeps my bb truck cool even on the hottest nc days.
72 CHEYENNE 10 SUPER 468/400/3.73 |
12-03-2005, 09:28 AM | #15 |
Re: Old air fans
how about noise? And what about your alternator how many amps alt are you running? Over all would you use it again?
12-03-2005, 01:12 PM | #16 |
Re: Old air fans
I think I have a 80 amp alternator best I remember. They don't run all the time just when temp gets above 180 d. Don't know about the noise I can't hear them above the pete jackson gear drive and hardly no mufflers.
I would buy them again.
12-03-2005, 01:42 PM | #17 |
Re: Old air fans
does one run all the time and the second one comes on when temp is reached? Or do both switch off and on together? Also were did you get that nice plate covering top of radiator?
12-03-2005, 03:39 PM | #18 | |
Re: Old air fans
Thanks |
