![]() Join Date: Jan 2004
ididit or flaming river
I'm about to spend some cash on a new column for the burb. Does anyone have any opinions on aftermarket columns, such as IDIDIT or Flaming River. Quality, fit, finish, customer service, price......any help would be appreciated. Thanks.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
![]() Join Date: Dec 2001
Re: ididit or flaming river
I used the Flaming River universal steering column (the diameter is the same as stock and fits right in), and redid the intermediate shaft using a couple of ujoints to get rid of the old spongy rag joint. I also had to modify the wires for the turn signal switch as it comes with the flat connector and the original is the crescent shaped connector. The quality is top notch in my opinion, and the tilt is definitely awesome. I bought through a local shop, so as far as their customer service I can't say.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Thanks greasemonkey! Any pics of your intermediate shaft and rag joint setup?
Here you go, this is with it test fitted- I am in the process of painting the truck now and will probably paint the column body color.
Just to specify, I don't have a rag joint anymore-just two ujoints and the intermediate shaft. Steering is nice and tight now.
67 is sold
That looks great Greasemonkey! Thanks for the pics
I like that. I think I would just figure a way to clear the steel if I get one. What length is it?
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
I second that greasemonkey! I like the idea of no rag joint. It's much cleaner. Thanks.
computer illiterate
i believe board vendor pickemup is a dealer for these columns
72 2wd blazer 72 swb 4x4 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I just started being a dealer for the Ididit columns. I would have to know what you wanted PN wise though.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Another option is a rebuilt original tilt column. In Canada they're $500 completely refurbished so you could probably get one for US $400 or so.
71 GMC 1500 LWB |
Here you go, I used the FR20007.http://www.flamingriver.com/index.cf...rod/prd266.htm
greasemonkey not to steer this off course but your gas pedal install looks really slick my PO just cut a slit and pulled it over the pedal. Wondering how you got yours to look so nice?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#13 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I think both are great quality either one should work for you..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#14 |
Broke and still trying
Ay greasemonkey, don't mean to hijack the thread Gregfull, but I noticed you have a manual tranny in there. What headers are you using? Do you have a part #? Sweet setup by the way.
#15 |
Outlandish Trends - FL
Looks great! I say leave it brushed aluminum. It'd be a shame to paint that thing.
-Bret 67 short-fleet sold! |
#16 |
A.K.A- Crummy
I really like the looks of that. Diferences in a 4x4?
2003 Silverado Z71 Are fishermen all liars? |
#17 |
"Trucks with Class"
![]() Join Date: Jul 2000
Just a little info:
The Flaming River columns are "Stainless Steel" and their dressup arms are really nice! Notice the bottom shaft on all of these aftermarket columns is "DD", so you MUST either use those nice u-joints (at about $80each times two plus the intermediate shaft, about $100) or pay a little more for the column and have it equipped with a splined shaft...to use the stock intermediate shaft. Last edited by PICKMUP; 02-10-2006 at 12:34 AM. |
#18 |
Flaming River columns are collapsable in collisions which is a big bonus for saftey. Not sure on the Ididit columns.
Mike
Mike Redpath |
#19 |
I used a Ididit column. It replaced the factory column exactly, but I changed to a floor shift. I had a problem with the turn signal switch and they sent a new one in the mail. The last time I called them about a problem with a bearing noise from the column they told me to send it in and they would fix it at no charge. I have had the column for 7 years.
#20 |
Pickmup is right, the column is stainless. I may just try to polish it, I think Pickmup has done that before (if I remember correctly). Mine came with the dress up kit included.
The headers are Flowtech, Summit # BIG-31500FLT. I will probably upgrade to a larger header one day with 1 5/8" primaries. The gas pedal is just a stock replacement, I think for the "custom" option. I just didn't put the chrome trim on it because I knew I would scratch it up.
#21 | |
I would expect any stock replacement to have the right connectors or I'd just stick with stock refurbished.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#22 |
"something witty here"
old thread but same questions pretty much, I have a 700r4 in my truck do they offer a column with an overdrive on the gear indicator rather than just P-R-N-D-2-1 that works with the 67-72?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
#23 |
sharp as a marble
![]() Join Date: Jan 2007
Put an IDIDIT in a 72 Blazer. Bolted right in wires hooked up as they should. The only thing I did not like was that the shift indicator was not illuminated, nor could it be. This was a customers car, did not bother him, but ??? The column we used was a steel paintable tilt with column shift.
#24 |
I wonder if the flaming river lights up, if not Im sure it wouldnt be hard to route a lil l.e.d in there.
#25 |
"Trucks with Class"
I am now having three more of the floor shift Flaming River "stainless" columns built. The same discount price with the billet ujoint included is offered one more time. Take a look. I don't want to turn this into my forsale thread, so I will take questions & put you in line over on this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=356539 Flaming River shift indicators (auto trans) are lighted and a close design of our truck columns. I have two of these left at last year's volume buy discount prices. Again go to my other thread...above. Last edited by PICKMUP; 01-18-2010 at 10:02 PM. |
