Old 12-01-2005, 04:44 PM   #1
smokie347
8-lug disk swap...
I searched and didn't find anything on this so I apologize if I missed something. I am trying to find out if the 71-87 8 lug disk brake parts swap, like the 1/2 ton parts do. I have a 68 C-20 with the Eaton 1 ton rear. I am turning it into a dually wedgeback car hauler to take my streetrods to car shows. I once found a site online that carried a kit that included drop spindles, rotors, calipers, but have since lost the link. Any help here would be greatly appreciated. Thanks Jeff.
www.twistedmetalfab.net
smokie347 is offline   Reply With Quote
Old 12-01-2005, 10:41 PM   #2
qksilver
Re: 8-lug disk swap...
Use the 73- 3/4 parts, they will swap easily plus parts are cheaper and you have rubber bushings in the control arms, so they ride better. As far as dropped spindles i would check with one of the vendors on the board. If it was just for show I wouldn't worry so much about the spindles but if you plan to use it for towing I would make sure that you use a high quality spindle. There is such a range from bad to good quality on spindles.
Steve
qksilver is offline   Reply With Quote
Old 12-02-2005, 04:18 AM   #3
smokie347
I think I am going to skip the dropped spindles. I am running 10 ply 235/85/16 tires in order to get the weight GVW limit up where I need it. When finished this truck should have a GVW of close to 18,000 lbs. I am hoping to be able to have one car on the wedgeback, and another in the 24ft trailer behind it. I am also considering a Duramax/Allison swap, if I can find a good donor truck. Thanks for the help. Jeff.
Old 12-02-2005, 10:24 AM   #4
qksilver
With those loads, the dropped spindles will give you problems down the road. With the later model swap, it's just like the 5 lug, except using 3/4. I would look at some high performance brake pads, they are cheap insurance and do stop better, just make sure that they are for towing applications.
Steve
