Old 12-01-2005, 07:57 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
Need help with A/C firewall...
Hi Guys and Gals,
I need a big favor from anyone that has a factory Air truck. There are two holes that I need pictures and a description of what is running thru those holes. I have circled both holes in this picture (actually, this picture is of a non air truck, so the hole on the curved part is not there), can someone get me a good picture of both holes with what is coming thru them?
THANKS!!!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-01-2005, 08:54 PM   #2
chevymaz
What are you looking at?
chevymaz's Avatar
Re: Need help with A/C firewall...
I went a took a look at mine and the only thing coming out the two holes is vacuum lines.
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 12-01-2005, 09:13 PM   #3
John Fabris
TOTY 2006
Looking at your picture, it looks like there are two vacumn lines, and one bundle of wires coming out of the three hole grommet. Thanks, that gives me a better idea of what is going on.
The upper hole should have the long cable from the A/C controls coming out of it...
John Fabris
67 C10 SWB
Old 12-01-2005, 09:23 PM   #4
chevymaz
chevymaz's Avatar
The wires coming out of the lower hole look to be a ground wire and a wire to the fan. The upper hole like you said is the cable that comes from the a/c controls.
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
Old 12-01-2005, 10:36 PM   #5
qksilver
I can get you a picture of a stripped A/C firewall. The 2 trucks I have with A/C are buried in the back of the shop. I just brought home a stripped cab and frame , so i could take some very clear pix of that firewall.
PM me your email and I will send.
Steve
qksilver is offline   Reply With Quote
Old 12-01-2005, 11:37 PM   #6
John Fabris
TOTY 2006
qsilver, I was trying to find out what was suppose to come out of those two holes and how they were run. I have a good idea now!!
John Fabris
67 C10 SWB
Old 12-02-2005, 12:42 AM   #7
John Fabris
TOTY 2006
Another Question, in the picture posted by Chevymaz, it appears that the wiring harness for the compressor comes out of the hole that is on the slope of the tranny hump part of the filewall, where on the firewall does the wire for the blower motor come out of?
John Fabris
67 C10 SWB
Old 12-02-2005, 06:35 AM   #8
chevymaz
chevymaz's Avatar
the wire bundle you see coming out of the lower hole by the vacuum lines is the blower motor wire. The wire bundle rolled up in the pic that go th the compressor come thru on the drivers side of the firewall. I can get get you a pic of where they come thru this afternoon if you need it.
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
Old 12-02-2005, 07:18 AM   #9
72 longhorn BB
72 longhorn BB's Avatar
I cobbed this off a thread just the other day.
It shows the reverse angle, from the inside, but I think it is what you are looking for.
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
