Old 12-01-2005, 08:33 PM   #1
tblough
Vaccum Switch
Hello,
I'm trying to find a part number or description for a vaccum switch on my 1984 250ci inline six. It is located almost in the center of the block on the passenger side. Any ideas how I can find it? I cannot locate it in the shop manual.
THanks,
tblough
I love my Truck!
'84 Custom Deluxe C10 LWB
Inline 6 250ci 4.1L 2wd
tblough is offline   Reply With Quote
Old 12-02-2005, 08:38 AM   #2
beaterC10
Re: Vaccum Switch
Try searching on "GM Parts Online" you should get several vendors that sell GM parts. They normally have a catalog you can look up GM part numbers in.
beaterC10 is offline   Reply With Quote
Old 12-02-2005, 10:55 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Vaccum Switch
If you want to know how it works (what temp it switches at, what it controls, etc.) I have no idea. If you just want to replace it, any auto parts store should be able to provide you with a replacement. When I changed mine, they just needed to know the application, the number of ports, and the color. I think the color identified the temp at which it started working.
Slonaker
Edit: I am not positive, but I want to say that it had a part number stamped on the portion that comes in contact with the coolant.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-03-2005, 06:45 PM   #4
tblough
Re: Vaccum Switch
Here is a picture of what I'm talking about http://www.geocities.com/timblough/whatisthis.html
tblough
I love my Truck!
Old 12-03-2005, 07:18 PM   #5
Slonaker
Slonaker's Avatar
Re: Vaccum Switch
I can't tell anything from the pic, and I am not familiar with 6 cylinders. Are you sure it is a vacuum switch? It looks more like a sender of some type, unless it is broken.
Slonaker
Stock '01 Silverado
Old 12-03-2005, 07:24 PM   #6
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Re: Vaccum Switch
That doesn't look like a vacuum port. Ports have vacuum lines running to them. This is a vacuum port.
That looks like some sort of sensor.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-03-2005, 07:38 PM   #7
tblough
Re: Vaccum Switch
It used to have a vaccum line running to it. The plastic is broken. that is why I am looking for a new one. I cracked it, the machine shop that did the rebuild finished it off. They don't know what part it is for either. Does anyone know of an old chevy dealership mechanic?
tblough
I love my Truck!
Old 12-03-2005, 11:46 PM   #8
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Re: Vaccum Switch
LMC Truck has all the TVS parts you can shake a stick at. Get the number off of the switch and the color. Most parts stores should have these or be able to get them. Don't forget to count the number of ports.
Brad
79 Scottsdale C20
350/350
3.73's
Old 12-04-2005, 12:53 AM   #9
tblough
Re: Vaccum Switch
Finding the part information, including part number, is the problem I am having. There is no visual part number.
tblough
I love my Truck!
Old 12-04-2005, 02:15 AM   #10
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Re: Vaccum Switch
LMC has a catalog with pictures. You might be able to look online and match it up. If not, you can order one or try to download what you need. That's the best I can tell you. Good luck.
http://www.lmctruck.com/pdfcatalogs/...9CC099-105.pdf Scroll down to pg 104.
Brad
79 Scottsdale C20
350/350
3.73's
