12-02-2005, 12:06 AM | #1 |
putting a th 400 in my truck
I have a 70 2wd with a 350 and a th 350. What will I have to do to put a the 400 in? Something with the kickdown or something. And is it longer then the th 350?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
12-02-2005, 12:24 AM | #2 |
Re: putting a th 400 in my truck
400 longer --mount differant place (just slide crossmember back)--shorten driveshaft and change front yolk to a 400
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
12-02-2005, 12:32 AM | #3 |
I just looked and I have the 9 in tail housing and a normal slip yoke design. Do you think I could run a one peice driveshaft with this trans in my long bed. I wont go past 61" for a drive shaft.
12-02-2005, 01:07 AM | #4 |
its all about the +6 inches
Do you have a LWB or a SWB?
12-02-2005, 01:13 AM | #5 | |
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
12-02-2005, 03:00 AM | #6 |
IIRC the Th400 kickdown is electric and for 67-70 the switch is located near the carb while on 71 up it is under the gas pedal.
"You can take the man out of PA, but you can't take PA out of the man" |
12-02-2005, 02:20 PM | #7 | |
12-02-2005, 05:55 PM | #8 |
I plan to make some power so I am going with the th400. I know 350's can take it but hey I allready have the 400.
Its a long bed, with the 9 in tail shaft. About how long would that driveshaft be?
12-02-2005, 07:41 PM | #9 |
Measure the driveshaft you have now, add 2 5/16" and thats how long it will be. You will have to measure yoke to yoke. Measure from the rear of your tranny yoke to the yoke on the rear end.
