1 ton running gear on a 70?
I have come across a 1980 4x4 van with 1ton running gear for a decent price, and I wanted to find out if the axles will swap into a 1970 k20 without any mods, or what specific fabrication would be needed to make them fit.
Also, does anyone know, will the rear be a dana 60 or 14bolt in 1980?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Re: 1 ton running gear on a 70?
The rear should be a 14-bolt.Who did the conversion?Was it Quincy or a TerraVan?You`ll need to I.D. the parts like the front axle and t-case.Is it a right-hand differential up front?Are you sure it`s a Dana60 in the front?Most conversions did use the heavier components/But,as vans go,they`re called 3/4tons(20 series) with 5-lug wheels and 12-bolt rears.So,a 1t van could just have the same stuff that would be under a 3/4t pickup.
If it`s a Dana60 r/h,it will pretty much bolt right on to your springs.There may be some work to get d-shafts and steering together,depending on what all you have.Nothing difficult,though.The rear will have staggered shock mounts and you can either change them to match your`70 location or change your`70 to staggered.That will require another cross-bar for the rearward shock.As long as it`s a GM-friendly drivetrain,it won`t be a big job.
honestly, I know nothing about the van, came across the ad, and its near my family on the east coast where I will be for the holidays, so I figured maybe I could take my truck, and a trailer with me on my way home, just wanted to see if it was a possibility first. I will try to find out more specifics, the ad reads that its original from the factory 1 ton 4x4 van....were these not optioned?
![]() Join Date: Sep 2005
I ran onto one a while back for a reasonable price so I called about it.It had a Furd D44 in the front {Drivers side drop} and a 14bolt in the rear.I have been told some had D70's in the front,but I think those were Quigleys.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
there is a d70 front axle? never knew that.
Currently this van is about 600 miles away, so what questions do I need to ask, and what pictures do I need taken to be able to get the best and brightest minds on this board to be able to answer what running gear is in it?
Yeah there are D70 fronts.They came in some 70's and 80's Dodge 1tons,some Dodge W400's and in some of these 4x4 conversion vans.They also are in the 04'+ Chevy and GMC 4500 and 5500 4x4's. There is other vehicles that they came in.The early Dodge ones were closed knuckle.It should have d44/d60/or d70 cast into the housing on the pumpkin.
Let me know where it is. I'd be happy to take pictures for you.
its in long lake NY, might be a little bit of a drive for you unless you are actually in the area.
#9 | |
