Old 12-02-2005, 12:16 PM   #1
74Chevy74
Fuel Delivery Problem on my 74...this is wierd?
Ok guys here is a wierd one... I just picked up this chevy last week I drove it home for 30 miles ran fine, drove it to work the next day and it was ok, then I got home and later had the truck idling in the driveway and it stalled? after that it would'nt start anymore? I unhooked the fuel line that goes to the carb, to test the manual fuel pump and cranked to see if it was getting gas, and it wasn't. I got this truck from my buddy who just put a fuel pump on it like 6 months ago, wll I pulled that all apart check things out, played with the fuel pump and it seemed to have vacum/pump, and put it back together.
After that I tested it again with the line unpluged from the carb so now I had fuel? so I drove it to my buddies house about 2-3 miles away and when I go to leave it wouldn't start? So I pulled the line off and once again no fuel? Can the line be plugged from the tank? I know the tank was almost full, so I know it's not out of gas or anything? anyone got any ideas?
74Chevy74 is offline   Reply With Quote
Old 12-02-2005, 01:34 PM   #2
86 GMG
Re: Fuel Delivery Problem on my 74...this is wierd?
fuel line to close to exhaust and causing vapor lock? small crack or hole in rubber line that cause the pump to suck air instead of fuel? fuel filter clogged once the truck sits a little bit the crude in it settles down and alows fuel to pass through? im out of suggestions other than maybe that darn expensive fuel tank switch i have heard several diffrent actions from this when it goes out. good luck anyone else have any ideas that i didnt mention
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 12-02-2005, 02:01 PM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
If our trucks use a sock on the fuel line that is down inside the tank??(cant remember) they tend to cause problems like that, but my first suggestion is to replace the $15 fuel pump. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 12-02-2005, 05:03 PM   #4
86 GMG
the sending unit i pulled out of my 86 had a sock you mentioned i didnt think of that it is another good idea to look in to but dropping the tank sucks. and if its like my luck it is full of gas.
Old 12-02-2005, 09:15 PM   #5
crossy
crossy's Avatar
no self-respecting Chevy full size truck owner ever rides around with a full tank of gas!!! -------------for long.
Hint- use a floor jack with a flat piece of wood on top. fuel weighs Appx. 7# per gallon
98 Vortec project.
94,3500,6.5L 4L80
Old 12-04-2005, 11:26 AM   #6
74Chevy74
Thanks for all the input guys, got it fixed yesterday, turned out something is wrong with the fuel tank junction for the dual tanks. I just by passed the whole thing and it fired right up!
Old 12-05-2005, 09:51 AM   #7
86 GMG
for $120 roughly will buy a new valve switch from the dealer good luck
