Old 12-02-2005, 02:42 PM   #1
Professor
Wiring Issues
A kid installed a battery in an 84 Chev pickup BACKWARDS -- he reversed the cables. (In his defense, it was after dark.) The fusible link blew at the starter. He says he replaced the fusible link but still is getting nothing when he hits the switch to try to start it. He has lights, but no gauges. I am going to look at it for him later, but what else can I look for?
He doesn't know very much about this stuff (obviously), so he may have spliced the fusible link in incorrectly. I am hoping that is all there is. Any ideas on what else to check? Once it starts we can check the alternator, etc.
Thanks!
Professor is offline   Reply With Quote
Old 12-02-2005, 03:44 PM   #2
chevyjr73
chevyjr73's Avatar
Re: Wiring Issues
the very first and most obvious thing i would check is to get a voltmeter or voltage light and check every single fuse in the fuse panel. could be something as simple as a blown fuse. i would have checked that before i even went for the fuseable link. good luck
chevyjr73 is offline   Reply With Quote
Old 12-02-2005, 03:49 PM   #3
Professor
Re: Wiring Issues
Thanks, jr73.
He checked them (supposedly) and they werern't blown. But the fusible link was toast. Anything else between the the source at the starter, the switch, and back to the starter that could be toasted?
Old 12-02-2005, 03:51 PM   #4
1974gmc
In Progress
1974gmc's Avatar
Re: Wiring Issues
when the fusible link blew on mine i had no power to anything
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 12-02-2005, 05:01 PM   #5
86 GMG
Re: Wiring Issues
i have done this twice (to much beer or maybe not enough) but both times on my 86 it burned the wire apart just off the firewall to the left of the brake booster there is a little plastic item that has two wires on it that are held on with bolts the wires have metal plate with holes in them mine burned about four inches down from this spot. the wire i burned both times was the one on the right it will also have a fusible link tube on it right there close to the plastic item the fuse maybe blown there but if not the wire should be broke right there somewhere
i hope this isnt confusing just a lot of info from someone that isnt educated enough to explian easily
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
