Vintage Evil
drip rail sealer
Hey guys
I am in the process of starting to refinish a new cab project of mine. The sealer that is in the drip rail is all dried, cracked, and falling out. I had orignially considered shaving it but am not sure. What kind of sealer do you use if i decide to keep it? Thanks |
Re: drip rail sealer
What I use is 3M automix #8307 self leveling seam sealer.
CUSTOM CHEVY FIEND
Shave'em Off, Cab Lines Will Look So Much Smoother. Thats Just My 2 Cents.
#4 | |
Vintage Evil
Thanks |
I think shaving is hard, and if you drive in the rain at all or your truck sits outside, you'll live to regret it.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
![]() Join Date: Feb 2004
3m body caulk -- water based. Clean out rail completely down to the bare metal. Read the instructions if you should prime before applying or not. If rust is found use a converter first. It can be smoothed if needed with a wet finger.
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Body caulk will tend to crack over time. I used the 3M 8307 seam sealer and it is as close to factory as you can get...only better. Just make sure you clean out the old stuff/rust & paint.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Agree with Botietruck, I used seam sealer in a caulking tube --it was water based.
3M Fast N Firm Seam Sealer
3M Fast 'N Firm Seam Sealer is a firm setting product for sealing interior and exterior joints. Adheres well to clean, bare metal, primed metal and paint surfaces. Skins over quickly. Low shrinkage. Can be painted within 20 minutes. Excellent tooling and sanding properties. |
#10 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
How much of the 3M automix #8307 would be needed to do our trucks? I see that they are sold in 200ml packs...Is one 200ml kit all that is needed, or does it need more than one?
Mike Last edited by BigMike; 06-14-2006 at 12:23 AM. |
I used Fast & Firm, but didn't like it. It was easy to use, but took about a month(no kidding) to completely dry, and now is starting to crack.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
#13 |
Firefighter
3m Auto Mix is the only way to go.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
