PROJECT 7DEUCE
![]() Join Date: Dec 2002
Did you have to cut?????
I am installing some headders tonight and they are crashing into the motor mounts should I just cut the mount to clear???? I f you have ran into this problem what did you do to claerance it??? btw its a 454 on 350 stands 2wd 1/2ton
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 12-02-2005 at 09:12 PM. |
Where's my beer?
Re: Did you have to cut?????
What headers did you use? I wouldn't cut any motor mounts, especially being a BB, lots of torque there.
Paul How do you make the invisible, visible?.........You take it away. |
![]() Join Date: Aug 2004
The BB stands have an extra bend to clear the original manifolds. Maybe the SB stands are too tall? I had Hooker comps on my old 396 and they cleared the BB stands by about 1/2" in that bent area.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
My bb mounts have a clearance curve right under where the mounts fit. Small block mounts don't....
i am not sure what company has them but there are tubular aftermarket mounts that are around 120 with mounts and they are suposed to clear just about anything. Steve |
Junior Member
we put a 454 in a 70 model with sb stands and the hedders hit the stands. had to change to bb stands and then everything fit ok
Yep, you need BBC stands. I tried it on sbc stands and it didn't clear either. I went through 3 sets of headers even with the right BBC stands before I found a set that didn't hit either the frame, oilpan or motor mounts. 3rd set was the charm.
PROJECT 7DEUCE
Here are a few pics...... Can anybody tell me what year these motor mounts are for?? Btw they are headman headders..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
What they said, mine didn't work either had to get BB stands, the ones that you have off look like the ones you need, with the dip in them.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 12-02-2005 at 10:36 PM. |
![]() Join Date: Mar 2003
When you install the correct stands the engine will be pushed back 1''. If you don't want to do that you will be drilling
I just had to notch the big hole a bit for mine, then used big thick washers from balancer bolts, you can also make some out of thick flat iron.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
Those your holding look like 68-71 mounts. The 72 mounts look like this:
its all about the +6 inches
the stand you were holding is the 68 - 71, the ones mounted are small block and then there's the 72 style ratrod posted.
#13 |
PROJECT 7DEUCE
68-71 Those Are The Ones That Have The Rubber Part That Is Hard To Find Correct????
#14 |
#15 |
PROJECT 7DEUCE
Thanks rat rod it looks like I have all the parts to make it work just need the harmonic ballancer washers.. Thanks guys..
