Old 12-03-2005, 01:16 AM   #1
corn
6 to 5 bolt question
I know, its been asked a million times but I cant find it on a search. If I convert my 6 bolt axle (1969)to 5 bolt what are my options besides a complete different rear axle. I heard the 6 bolts are narrower maybe? Send the axles & have them redrilled? Anything easier?
corn is offline   Reply With Quote
Old 12-03-2005, 04:02 AM   #2
HeavyD
HeavyD's Avatar
Re: 6 to 5 bolt question
I have been told by a few people that mid 1970 was the year they widened the rear housing, so your 69 will not work with 71 and up axles. You might be able to get the axles redrilled but I would buy another rear. They can't be hard to find, there are tons of these trucks all over the place. Too bad we weren't a little closer...I would sell you a complete driving 71 for $300 bucks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 12-03-2005, 08:31 AM   #3
70GMCer
70GMCer's Avatar
1967 thru mid year 70 requires 1/2" spacing behind the backing plates & also you must use the late 70 thru 72 brakes & drums. Check the build date on your rear, (man, that sounds personnel), to see if you have the wider one. The wider ones are 3/4" longer than the late 70's. This is assuming that you still have the original 12 bolt rear on the truck. This is what I've read on here a while back. I'm still thinking on doing the swap myself......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-03-2005, 08:45 AM   #4
Hart_Rod
Hart_Rod's Avatar
Early Classic sells conversion axles:
http://www.earlyclassic.com/catalog....ry=New%20Items
I put these on my 69 Burb, it was about a 1-2 hr swap.
Rob
Hart_Rod is offline   Reply With Quote
Old 12-03-2005, 02:14 PM   #5
corn
Thanks guys. Where can I find the # on my stock axle? ...corn
Old 12-03-2005, 05:13 PM   #6
Solver
Solver's Avatar
Corn usually right about the red circle
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-03-2005, 07:08 PM   #7
corn
Thanks Solver! Ill check it out...
Old 12-03-2005, 09:36 PM   #8
cduster
I converted my 67 rear to 5 lug using the kit from early classic. The link Hart_Rob posted is it. Nice quality axels, and reasonably priced, IMO.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 12-05-2005, 12:06 AM   #9
67-72chevyman
Do any of you know the length of those axles?
67-72chevyman is offline   Reply With Quote
