Old 12-03-2005, 12:38 PM   #1
76bonanza
76bonanza's Avatar
TH400 question
In an effort to find this whining sound in my truck I think it is the tranny. When it is cold outside I get this high pitch whine after I start it for a few seconds like 45 or so sometimes longer if it is real cold then it stops then when I put it in drive it does it again for a short time. Does not do it all when warm. Wondering does the th400 use gears instead of belts because that is kind of what it sounds like maybe untill the tranny fluid warms up? Any thoughts on this subject would be welcomed.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-03-2005, 03:49 PM   #2
cdyblu
cdyblu's Avatar
Re: TH400 question
I don't know of any "belts" in any automatic transmissions, It sounds to me like you have a converter problem or front pump. First thing I'd try it a filter & fluid change.
cdyblu is offline   Reply With Quote
Old 12-03-2005, 04:37 PM   #3
76bonanza
76bonanza's Avatar
Re: TH400 question
I did the fluid and filter about 1 month ago was rebuit about 6 months ago Not really sure it is even the tranny or not, shifts great runs strong. Just that wierd sound and only when cold thought maybe the tranny fluid was just cold. like 20degs for so.
1968 c10
lowered 3" 4"
Old 12-03-2005, 04:48 PM   #4
chuck1960
Junior Member
chuck1960's Avatar
Re: TH400 question
you just have three converter bolts, you can remove these and push the conv. back then start it up and see if you still have the noise. this will eliminate the trans. have you checked your acc. drive belts, p.s., alt. a.c.?
chuck1960 is offline   Reply With Quote
Old 12-03-2005, 06:50 PM   #5
jracca
Re: TH400 question
I may just be an idiot but I had a sound that is like you described and thought it was coming from the transmission and it ended up being the support bearing on the driveshaft, you probably already looked but just in case you didn't and you have a support bearing you might want to check it
jracca is offline   Reply With Quote
Old 12-04-2005, 01:24 PM   #6
alf1096
alf1096's Avatar
Re: TH400 question
my th400 does the something similar. It whines for about 2-3 miles and then it quits but it does not do it while it is idling
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 12-04-2005, 01:36 PM   #7
409biscayne
409biscayne's Avatar
Talking Re: TH400 question
I thought my t400 was whining , but it turned out to be the wife . Ha ha. My ps pump makes noise on cold start up . Hope you find your problem .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 12-04-2005, 07:38 PM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: TH400 question
My guess to your problem is a trapped air bubble. I had this same sound from my th400. My solution turned out to be a good tranny additive. I think it was Sea Foam tranny conditioner. The sound went away shortly after adding the conditioner.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-05-2005, 11:56 AM   #9
Lemield
Lemield's Avatar
Re: TH400 question
I had the same noises in my C20 and a filter change fixed it. Good luck!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 12-05-2005, 01:06 PM   #10
76bonanza
76bonanza's Avatar
Re: TH400 question
So what exactly is the difference between the th350 and th400 I thought one had bands and one had gears?
1968 c10
lowered 3" 4"
