12-03-2005, 12:51 PM | #1 |
chevy freak
best way to lift my truck.
hey i have a 76' gmc 3/4 ton 4x4 and i want to get around 15 to 20 inches of lift. what do i need, because i havnt found any kits for more that 10 inches. If anyone has some parts they want to sell me for this i would apreciate it. thanks
12-03-2005, 01:47 PM | #2 |
Re: best way to lift my truck.
What in the hell do you want to lift it that high for?? Just get some flat stock and have it bent to like a U, so the high side of the spring is about 22" from the ground to the center pin. You will get more flex out of that than a set of springs. Either get a custom set of springs, drop down hangers, probly both. Probly a body lift too.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-03-2005, 03:37 PM | #3 |
I'm thinking that this is one of those "If you have to ask....." types of questions.
It is far more involved to get something like that working than your typical kit can offer. If you really don't have a clue about where to begin........leave it alone. |
12-03-2005, 05:39 PM | #4 |
a kit? there isnt one.. it depends on what you plan to do with it and how much $$ you want to spend...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-03-2005, 07:14 PM | #5 |
user # 2756
12" superlift springs & 3" bodylift for off the shelf stuff. After that it's all custom. Then you have driveline angles/steering correction to contend with. If your 3/4 ton is stock, the dana 44 up front will have to be replaced. Then gearing for the larger tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
12-03-2005, 11:13 PM | #6 |
Hope you own a bank. Cost lots of money to do what you are asking. Like
Jims70gmc has stated if you have a dana 44 forget using it. You really need to do a straight axle conversion and go with one ton stuff. You didn't say what your plans for using this truck were but with that much lift you will be putting a lot of stress on the running gears and with those large tires you will need crossover steering to take out some of the bump steer. I never want to toss cold water on anyones ideas but I just want to point out the fact that it will take a lot of work and a lot of cash. Good luck. |
12-03-2005, 11:39 PM | #7 | |
12-04-2005, 04:31 AM | #8 |
I know www.offroadunlimited.com sells custom knuckles to correct for the steering parts likeyour draglink and tie rods....so they might be able to help you out with the rest.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
12-04-2005, 10:34 AM | #9 |
That much lift is unnecessary I think. It would be hard to get driveshafts to work unless it's a crew cab long box. My brother has one with around 10" of lift and it looks like it's all the higher you would want to go.Actually it may be a little big.He doesn't have driveshafts yet so I can't say how that will work yet. If you want 10" I would go with 6" rears up front and 6" rears and a shackle flip in the back.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
12-04-2005, 11:07 AM | #10 |
I had a 8" suspention lift, 3" body and cut out fenders to clear my 44"s. With that setup, my driveline angles werent that bad. I used a drop pitman arm and a drop drag link for the steering. The tires would rub every now and then but rubbins racin
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
12-08-2005, 04:34 PM | #11 |
chevy freak
For all who asked why.... THis is what I had in mind for my 4x4. I had to sell my 87' dually about 2 years ago. it was on 37inch swampers and I loved it. it was around 8 inches shackle flip. I wanted to keep my 76' stock axles for a while though till i have the money for dana 60's. How much can a stock dana 44 go for?
12-08-2005, 09:21 PM | #12 |
That Red truck looks like it might have 10" or so.It looks pretty cool.The D44 will hold 35" if you're wheelin it hard.Much bigger if you aren't wheelin' it. Keep me in mind when you are ready for a D60.
12-09-2005, 05:28 AM | #13 |
custom suspension will make you anything up to a 30in lift spring... customsuspension.com hope that helps
12-09-2005, 11:32 AM | #14 |
chevy freak
hey 1967k30 how much for a d60??
12-09-2005, 02:36 PM | #15 |
12-17-2005, 10:12 PM | #16 |
Born Psycho
many years ago there was a goofy kid here in town with a late 70s f-150, he put on the biggest lift he could get but it still wasn't high enough for him so he bought another truck the same vintage, pulled everything off of it and stacked the frame on top of the frame of his first truck. it ended up super high-- then it ended up on it's lid.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-18-2005, 09:57 AM | #17 |
If you really want to lift it, Jerry Moss reminded me of what my buddy Chuck did. He did this to two trucks. I should be able to get pics of the latest one. He has a Ramcharger that he stacked the frame on. Put the motor and trans in the lower frame so it's too top heavy. I think he said a 6" lift, but then just an add-a-leave, so not really sure, then a 3" body lift, and it clears 44s with ease. Maybe clear 49s. Only problem I see and he had, was with the drivelines. He ran a div. case, and his rear driveshaft was maxed out sitting there. I think stacking the frame is good for 6-7" of lift.
sbc940, I can sell my D60 front out of my truck, it's completely rebuilt. I have a new set of 4:56s that go with it, just need a carrier and install 'em. Truck has 3:73s in it now. $1500.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 12-18-2005 at 09:59 AM. |
