12-03-2005, 07:09 PM | #1 |
Computer control box installation.
Does anyone have a pic of how the silver control box and plastic retainer tray fasten behind the glove box on on an 87 chevy pick up. Pic would be a great help. Thanks.
1986 Silverado Short box fleet side. project 2005 VW Tiguan 4 Motion 1997 Blazer S10 4x4 1990 Chevy Silverado K1500 Extended long box |
12-03-2005, 09:08 PM | #2 |
Professional Grade
Re: Computer control box installation.
I've been trying for months to get someone to post a picture of just this, lol
Watch as someone posts one up for you just to spite me
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-03-2005, 09:42 PM | #3 |
Russell, I might go take a pic later just to spite you.
12-03-2005, 11:09 PM | #4 |
Real Men Wear Orange
http://i6.photobucket.com/albums/y20.../IMG_10201.jpg
Is that the right thing? I thought that was a prehistoric ignition computer of sorts. It's an '85 model if that matters... |
12-03-2005, 11:49 PM | #5 |
Same idea as the 87, but the 87 is bigger. That's the ECM in the pic I believe. The 87 is a little bigger and has more wires coming out of it. Thanks, that gives a basic idea of where it goes. I am putting an 87 fuel injected motor in a 86 cab and had to change the whole wiring harness and the person that was helping took the unit out before i had a chance to see to see how it was installed. The 86 was already out when I got it. Thanks again guy's.
12-03-2005, 11:51 PM | #6 |
87 GMC. I dare you to take a pic just to spite Russell. Go ahead I double dare ya.
12-04-2005, 12:15 AM | #7 | |
12-04-2005, 12:29 AM | #8 |
Just trying to have some fun. No offence. Sorry if I upset you.
12-04-2005, 12:45 AM | #9 |
I am not a hater and I take offence to that. This is not a forum for personal attacks. I told you I was sorry if I had upset or offended you and I stick with that. Thank you.
12-04-2005, 03:09 AM | #10 |
Professional Grade
lol
Free -- He isn't meaning to be offensive Just joking around About that picture Mr 87.... I wanna see it here tommorow night!
12-04-2005, 03:33 AM | #11 |
Sorry...no pictures to share but i am well aware of the how it goes together part. 87 up cabs have a recessed section in the interior section of the firewall above the heater box. I actually learned this lesson the hardway as i thought i'd be slick and mount the ecm in my 76 chalet in such a manner so i went to gm and ordered the bucket...the screws and the two weld on brackets that everything attaches too. At this point and armed with all the parts i realized plan b was necessary unless i wanted to remove my entire dash and french in the firewall so i could use the parts i bought. So for me plan be was obtaining a grommet for the ecm harness from a boneyard....removing a heater box from a spare K5 out back...determining i could mount the ecm directly to the heater box and never get near enough to having a screw puncture the heater core. So i nabbed some sections of aluminum cab structure from a frieghtliner sleeper to provide to pieces of aluminum angle iron to mount the ecm to....and since heat and ecms don't play well together i used some really thick silver backed reflective material to shield the ecm. I then hit the junkyard and scrounged 4 ecm mounting screws used on gm cars....the plastic spud looking ones that are sometimes used by gm to locate the ecm in a mount....then i drilled 6 holes thru the aluminum angle....and used gm screws used with fiberglass components as they have two sets of threads. And its worked for over a year now with no ill effects. Sorry to be long winded but i thought i'd share my alterative approach to the matter as my first go around wasn't so pretty in my 79 blazer.
Basically if you have a CCC cab forward which i would have to guess the ill fated expensive CCC carbs hitting the scene in 84-85 the cabs have the notch in the firewall for the ecm bucket for lack of a better term. That being said the cab should allready have the two brackets with the z bends in them tack welded in this area. I gave away a complete set of brackets...bucket and the strap that holds in the ecm last year at blazer bash but i think i still have one bucket upstairs in the attic. Hope this helps you out. Doug W.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
12-04-2005, 12:18 PM | #12 |
Thanks Russell.
12-04-2005, 12:23 PM | #13 |
I thought that there should have been tabs there as well, 76. I looked last night and could not find them. Cab is an 86 as that is what the ownership and the guy I bought it frm says. Will have to take a better look today and make sure. Thanks for all the help.
PS thanks to everyone for the help and sorting out the misunderstandings.
12-04-2005, 01:58 PM | #14 |
When i we get this well drilled and i get to go home i can look the PN up in my RV series bible for those brackets then go see michael at my chev dealer and see if they are still ava.....might be a week or so as this rig has had nothing but problems so far...
Doug Wright
12-04-2005, 04:31 PM | #15 |
Thanks 76.
12-04-2005, 10:15 PM | #16 | |
