Old 12-03-2005, 09:03 PM   #1
special70gmc
special70gmc's Avatar
Hhheeelllppp!!!!
My 87 1\2 ton is being an A$$. Its at my shop with half of a 6 inch lift in it and the pitman arm is stuck on it. Any ideas on how to get it off??? the impact hammer isnt working, the torch is out of O2, the sledge hammer broke, and the sawzall is my next step... Somebody help me.
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-03-2005, 09:05 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: Hhheeelllppp!!!!
Got access to a hydralic press?
Those pitman arms are a HUGE pain in the royal butt. You'd better get a new sledge!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-03-2005, 09:21 PM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Did you trying using a pitman arm remover tool? You can rent them at Auto Zone or most other places.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-03-2005, 11:05 PM   #4
Trimman
Trimman's Avatar
I used a pully puller to remove mine
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
Old 12-03-2005, 11:12 PM   #5
SlapFish
Real Men Wear Orange
Rent a biker to yank it out with his hands. They's some big dudes...
SlapFish is offline   Reply With Quote
Old 12-04-2005, 08:55 AM   #6
Tom's 68 conv
chevy junkie
Tom's 68 conv's Avatar
pittman arm remover
and a hammer to tap it as you are applying pressure
Tom's 68 conv is offline   Reply With Quote
Old 12-04-2005, 01:51 PM   #7
special70gmc
did i mention its 4wd.... i think i forgot that detail. and are there sleeves around the studs that lock the arm in place? i have a new raised arm and it seems to be a cone shape where the nuts go on...possibly so a lock type sleeve can slide in? maybe thats why i cant get it off? this isnt cool. now i have no truck. and also, my rear springs seem to sag alot. after the suspention part of the lift was installed the rear of the truck sank 3 inches lower than the front. GGGRRRRRR
1958 belair 2door
Old 12-04-2005, 02:01 PM   #8
special70gmc
how would you use a puller on the arm... arent they just for the 2wd trucks with the arm on the steering box?
yea im lost
1958 belair 2door
Old 12-04-2005, 07:32 PM   #9
bbchevy
87 Wanna Be K30
bbchevy's Avatar
i was on my friends name before.... but anyway, iim stupid because i was talking about the steering arm, not the pitman arm. so yea... how do you get the steering arm off??? sorry about that.
bbchevy is offline   Reply With Quote
Old 12-05-2005, 05:30 PM   #10
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I don't think you can use a pitman arm puller for 4bys. I read somewhere? on how to remove one that was 'stuck' on, but I don't recall how... Try the folks at coloradok5.com.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-05-2005, 11:11 PM   #11
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Sounds more like the steering arm than the pitman arm. The steering arm has 3 studs with cone shaped washers holding it on. I had to use a BFH and beat the h#&& out of it to get the cone washers out...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-06-2005, 03:17 AM   #12
Americanrider
I just did one last week on a Dana 44 that had been sitting in the Washington rain for years, the axle was out in the back yard so it was fairly easy. 3 wacks w/ 18lb sledge hammer from the bottom side and all 3 cones came lose. If your axle is still bolted up to you truck it will be harder. Soak the cones in penatrating oil before you start.
Americanrider is offline   Reply With Quote
Old 12-06-2005, 09:41 AM   #13
bigarmzz
bigarmzz's Avatar
those damn cone shaped "dowels" are a *****!
i use a torch to heat them up red hot...then a screwdriver to peck them out(they screw out ya know)....then a bfh to whack the arm loose...some times i've had to use a gear puller and an air chissel....there's really no easy way ...the steering arm is the hardest part of putting a lift kit on these trucks
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
