FIRE FIRE FIRE!!! Fuel filter NO! NO!
Well it started with a great day. Went to the barn to meet a boardmember that bought a swb frame. On the way my 67swb starts to run bad.
I'm on I-20 going West between Ft. Worth and Weatherford. If I can just find a auto parts store I'll be ok. Well that was an adventure all it's self. Anyway, I find a NAPA auto and limp in. I find that the fuel pump has decided that it wants no more, and kills over. I place a call to fellow board member TxFirefighter, and he drives 30min to help. (WHAT A GUY!) NAPA had the fuel pump I needed and a bolt to help on the change out. They even let me borrow some tools for the job. TxFirefighter (AKA Kevin) pointed out that the glass fuel filter I had installed needed to be removed and the fuel line repalced also. Well I just need the truck to run so I could make the appt. FYI. Glass fuel filter and bad hose are not the formula for a great runnng truck. On with the pump and truck was running good. Make the swb frame swap, truck still running good, THEN, just like before, the truck felt like the fuel pump stopped working. Popped the hood to take a look. Fuel is leaking out the glass fuel filter. So I look around and find a building supply store. Surely they have something that may work to replace the fuel filter, too get home. After talking to the guy there we found a 3/8 nipple that would take the place of the fuel filter. I go to replace the glass fuel filter and the thing just comes apart in my hands. GAS!! spewing all over a hot motor, and on my hands and shirt. (Incert cheep Key Stone Cop Joke!) I'm sure the people driving by are still talking about the a$$H@># Jumping and running around a truck like a fool. Boy that was me! I have never seen so much fuel at one time. All I could do was try to stop the leak. Nothing was working. I ran to remove the fuel cap too take the pressure of the tank, grabbed a cloth in the back of the truck to keep the fuel off the hot exaust manifold., and still the fuel was runnng out. then it hit me. I may be looking at a fireball, and there is a burn ban in the county I'm in, then this image of TxFirefighter starts saying "that fuel filter and hose needs replaced". All this happend in just a few seconds. I could have burned my truck and myself to the ground. I said all that to say this. If your running a glass fuel filter and bad hoses, replace them NOW!!!! Don't waite till you get a chance. What really happened to the truck? I think that the fuel pump did bite the big one. When I replaced the fuel pump, well the pressure is greater to the carb now. The cheap glass fuel filter and hose didn't want to take the extra load, so they started to leak. When I touched the filter it just came apart enough to spray fuel all over the place. I may have a problem with the needle and seat in the carb also. I have purchased a new metal filter, fuel line, carb kit, and a fire extinguisher for the truck. Ya'll laugh now, Matthew
69 swb stepside, rebuild and upgrade in progress |
Re: FIRE FIRE FIRE!!! Fuel filter NO! NO!
WOW, sounds way too familiar. Those glass filters should be banned. Mine never got that bad, engine not as hot either, but pretty much the same result. Now I run teh plastic see through filters, much safer.
67- 72 Parts collecter |
hope you purchased a metal fuel line to do the job correctly and safely//more than 3"of rubber hose is a bad deal!!!!
i have had the same exact thing happen to me but i was on a date when it happend and needless to say i was wearing some nicer clothes and i was not a happy person when the ordeal was over but it does happen
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
"Trucks with Class"
![]() Join Date: Jul 2000
I have had two of those glass filters come apart...threads stripped right out and dumped gas all over the running motor. I warned Summitt & Russell (yes, this was the good stuff with AN fittings and no rubber hoses!) and they just gave me the old BS line: "No one else has ever complained"...so there can't be a problem---right?
I now run billet alum filters with steel braided hose and AN fittings. No clamps, no leaks and no problems---ever! Even on six cylinders. |
Wow there's one of those on the Jimmy, never gave it a second thought. Thanks for the tip, I'm going to change it before the next time I run it.
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside ![]() 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
no brain no headache
man you were lucky. I always cringe when i see glass filters
![]() Oh and a big pat on the back to Txfirefighter for helping you out ![]()
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Once on one of my trucks, I was trying to figure out why the motor would start, then die immediately. I thought, carb clogged? fuel pump? Or the crappy ignition switch rig job. I disconnected the fuel line(but thought I had hooked it back), hit the starter. AND BOOM!, fire I mean the whole compartment most have had fumes it was a big flash. I thought it was going to burn to the ground. Luckily I had a icechest and was by my water faucet. I felt like N.dynamite, friggin idiot. My 80yr old neighbor actually got a good laugh out of watching me sprint and put it out from inside his house. A few replaced burnt wires and all was good. It was the bad ignition switch wire.
Another time I was messing with a S10 that had been sitting for several years and tried priming the TBI, mild fire too. It was in a field. I put it out with the air filter lid and a very fortunate puddle next to it. Very Scarey moments to say the least. Good thing I can react in those situations some people get the deer in the headlights look when fight or flight response comes on. Everyone be careful!! |
#9 | |
Out of the carpool lane.
I hear what you're saying, but I LOVE having my glass fuel filter. I only tighten it slightly more than finger tight and I've never had a problem. I can even loosen it with my fingers if I need to. I suspect that the ends were on too tight and that's why it disintegrated in your hands- could that be?
However, I do need to replace the molding short fuel hose in my Camaro and now I think it'll be a priority!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
i also like the glass filters never had a problem 15 yrs pr so.i run 1 on my 8 sec mustang with a 402bb chevy at 140mph.they need to have the ruber gaskets changed every so often so the filter wont loosen and leak. never overtighten them, glass wont take the torque. BUT i do check it every time the hood is open.
![]() Join Date: Mar 2003
I put my fuel filters underneath the truck away from any engine heat.
#13 |
brittle piece of glass with fuel in it hanging over hot engine..hmmmmmmmmmm
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#14 |
Glass fuel bowel filters belong on old tractors only.
67 GMC 4x4, 305 V-6, 4-spd 86 S-10, 2.8 2WD LWB 01 Suburban (family hauler) 13 Honda CRV (wife's wheels) 03 Malibu (daughter’s car) |
#15 |
There was a recall of some of the tubular glass filters about ten years ago due to some fires. I wouldn't use one for any reason. I've had one of the metal inline filters develop a tiny rust hole in the bottom on a car that didn't get driven much, but I smelled the leak before it caused a problem. I prefer the clear plastic ones made by Wix.
#16 |
Never use a glass filter again. My son had one on his truck and it broke and started a fire. Now the truck sits along his house and we are going to have to replace every rubber item. Lucky when it happen some one called 911 and the fire dept put it out. The engine compartment it all screwed up now after the fire dept finished with it but it can be brought back to life once it is all cleaned out.
68 Chevy short wide air cab 4/6 on the drop 327 small block Front disc Frame "c" sectioned Gaylord bed cover |
#17 |
![]() Join Date: Jan 2002
I had one on my truck but took it off immediately after I was warned they are prone to leak or break and cause a fire. I figured why chance it, even if the chance was small and got rid of it.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
#18 |
Its Magically Delicious
so if glass isnt the answer .... who makes a good steel or aluminum fuel filter ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#19 |
I just had probs w/ glass filters
#20 |
![]() Join Date: Feb 2002
I never had that bad a problem with the glass filter. I have noticed that since they started adding ethanol and ether to fuel in the winter around here [Az], that the plastic replacement elements inside the glass filter would swell and inpede fuel flow. I suppose with old brittle O -rings that could be a liability. I have one glass filter as a strainer just before my fuel pump but I re-use the micarta element w/magnet. Just before the carb I use a steel Fram G-11.
Once I used a plastic see-thru gas filter just before the carb on my late '67 K/10 Sub w/ 454 and K&N air cleaner. A backfire caught the air cleaner on fire and the heat melted the plastic unit. Since the fuel pump [Holley Red] was controlled by a switch under the dash and not dependent on motor running [or oil pressure switch], it kept flowing. Things could have gotten a lot worse if some quick-thinking guys from the motel staff had'nt jumped out with extinguisher bottles just then. As it was, I had to tow the Sub home to Tucson from Southern California w/ a U-Haul tow-bar. And now it's just another future project to get up and running again. Pickmup: Sweet looking 292 there.
#21 |
I`ve seen some nice vehicles burn from those glass death traps.I used them on everything for years.Like the others that say they`re ok,I never had a problem.I decided I didn`t need to wait for my truck to burn to believe the danger.Why gamble?There are better,safer alternatives.
#22 |
![]() Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 01-01-2006 at 11:21 PM. |
#23 |
![]() Join Date: Feb 2001
I had a bad experience with a glass filter also. -20 below wind chill and I drove down the interstate for 15 miles using about a 1/2 tank of gas before I could stop and see why the bad gas smell. gas was froozen all down the side of the truck. (tan ice).
