Old 12-03-2005, 11:50 PM   #1
aggiedave98
how to grease door??
My door is "squeaking" when I open and close it. Where do I grease it and with what kind of grease??
thanks!
aggiedave98 is offline   Reply With Quote
Old 12-03-2005, 11:55 PM   #2
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Re: how to grease door??
Grease around the hinges and pins. I like to use white lithium grease but some penetrating oil or WD-40 will work too.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 12-05-2005, 03:09 AM   #3
84 400
Sb 400 club
84 400's Avatar
yeah use white lithum it can make an awfal mess but works great. also do the hood latch and hindges while ur at it . my dad years back had a hood do the famous chevy bend cause it was dry hindges. but now they make speacial reenforcements to fix that problom.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-05-2005, 05:10 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I use white lithium as well on all moving parts. I usually clean them before applying the lube. I need to do the door locks and latches.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-30-2005, 01:30 AM   #5
aggiedave98
I tried putting grease on the two little "roller wheels" but it's hard to get it in there. How do you get the grease on there? How do you get it on the hinges itself??
Old 12-30-2005, 02:33 AM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
Just soak the hinges in grease, the lil pins and anywhere the hinge moves. Then clean up the mess.
Thats what I do at least....
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 12-30-2005, 09:35 AM   #7
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
I use electronics parts cleaner to remove the old dirt and grease because it wont hurt the paint, then I use the white lithium grease that comes in a spray can. It gets into everything and does a great job.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 12-30-2005, 03:36 PM   #8
SSC's76
No No
SSC's76's Avatar
A wet graphite lube is the best and will outlast sticky lithium. Thats my weapon of choice.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 01-04-2006, 02:35 AM   #9
boxrodz
boxrodz's Avatar
SSC776 -
Is that the lube that goes on wet and then ends up dry?... something like 'Lock-eze'? What is your weapon of choice and where can find it? I'm willing to try something new. - Thanks.
boxRODz
