Old 07-12-2002, 01:47 AM   #1
Blue_71
Bloo
Blue_71's Avatar
engine decoding? (tried nastyz28.com and mortec.com)
i used the numbers off the back of the block for mortec, and they showed my motor to be a 68 302, 68 327, or a 68 350... i cant find the suffix code off the front on nastyz28, here are the numbers
V083OHF
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-12-2002, 02:26 AM   #2
dmec
dmec's Avatar
engine numbers
sounds to me as if you are using the wrong numbers. should be numbers with no letters. they will be cast into the block not stamped.
dmec is offline   Reply With Quote
Old 07-12-2002, 02:34 AM   #3
Blue_71
Bloo
Blue_71's Avatar
the cast numbers are the ones that showed 68 302/327/350
i was just trying to confirm which of the three it was.
thanks
1989 Chevy K2500
Old 07-12-2002, 02:41 AM   #4
Southpa
Southpa's Avatar
There is a chance that the "O" is actually a "0" (zero) making your suffix code HF. The suffix code is stamped into the machine pad on front pass. side of the block.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-12-2002, 02:50 AM   #5
Blue_71
Bloo
Blue_71's Avatar
i cant beleive i didnt think about that could be a zero... back to z28!
1989 Chevy K2500
Old 07-12-2002, 02:53 AM   #6
Blue_71
Bloo
Blue_71's Avatar
well, that slightly helped... almost kinda
1965 HF 327 h/p 300 4 Vette
1966 HF 327 Powerglide, A.I.R. 275 4 full size
1969 HF 350 Powerglide 275 2 A F X
1978 HF 350 LM1 170 4 Firebird
still stuck between 327 and 350 (which i knew it was one of those two) guess ill just stick to calling it a 355 untill i find out otherwise
1989 Chevy K2500
Old 07-12-2002, 08:47 AM   #7
bigjimzlll
bigjimzlll's Avatar
the 327 will have the breather coming out behind the intake, and have an oil fill in the front of the intake
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
