Old 12-04-2005, 07:27 PM   #1
matthufham
mirrors help
can somebody post pics of your c10 with 92-96 f150 mirrors on. what i'm wondering is will it bolt right up with nuts on the inside, will the contours match between f150 and 67-72, will the adjusting bracket/tab work if you cut a hole on the inside of the door? i'm wondering because i've seen a couple of 67-72's that look good with these mirrors, and i found some on ebay for $4.99 each, they were manual with the adjuster.
thanks
matthufham is offline   Reply With Quote
Old 12-05-2005, 12:38 PM   #2
matthufham
Re: f150 mirrors help
ttt?
Old 12-05-2005, 01:08 PM   #3
grebus1
grebus1's Avatar
You might want to check out this thread from the Burb board: http://67-72chevytrucks.com/vboard/s...d.php?t=134457
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 12-05-2005, 05:20 PM   #4
matthufham
sweetness, thats perfect. thanks a ton!
