? about 67-72 "Bolt-In" C-Notch
Those of you who have done this Classic Performance Products Bolt-In C-Notch, did you have "issues" with the 2 bolts on the outside rear portion of the driver's side notch? On my setup the lower more forward of the two is directly in line with the 2 bolts that come in from the bottom. The other bolt hole is directly in line with the crossmember that is just behind the rear end, and the bolt won't go all the way in. I'm thinking that I will just drill some more holes that aren't in line with anything, but I figured I would ask to see what others have done for this situation, if you even had the same problems.
Thanks in Advance,
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
![]() Join Date: Apr 2005
Re: ? about 67-72 "Bolt-In" C-Notch
Had the same problem with mine, I just used a half inch shorter bolt. Not quite as "easy" of a project as I thought, of course I was doing it on a 69 Suburban with the body still on.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Hell it ain't easy with the bed off of my truck. I hate grinding rivets!! I guess it might have gone a little smoother if I had a plasma cutter & a fire hammer
I used an air chisel on most of mine. That is a tool worth it's weight in gold! It's just funny reading the directions. I think it list 5 or 6 steps!!!! Are you kidding me? I think I have about 8 hours in the project and about 3 to go. Are you using lowering blocks also? I added some 1 1/2 inch blocks. I'm wondering if I'm going to need a shock relocation kit? I guess I can add that later. I popped the rivets out of my upper shock brackets and bolted them in just in case I want to change it later. I'll try to put some pics up when I get done.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-04-2005 at 10:03 PM. |
Yeah I'm using 2" "homemade" lowering blocks. I already had ECE's 6" rear drop kit (springs, super panhard, and shock relocators). I put this notch in so that I could use the blocks to get it a littler lower without having to switch to airbags (yet). I can tell you that with ECE's shocks and relocaters and the 2" blocks, I can jack the rearend all the way into the notch without the shocks bottoming out. If you need I can get some pics real quick.
Yeah the directions are a joke!
Pictures would be awesome.
Thanks, Rob
I'm assuming that since your running airbags you would like to see how everything fit with it all bottomed out, right?
Here ya Go!
The first pic is just an overall shot, but you can see my 2x2 square tubing lowering blocks. The second pic shows how I "clearanced" the upper shock crossmember, because the differential was hitting it. The third and fourth pics show the clearance between the c-notch and the u-bolts on each side. The fourth pic is kinda blurry but it has the same amount of cleance as the driver's side which is roughly 1/8 of an inch. BTW these are taken with the axle tubes pressed up on the bump stops.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 12-05-2005 at 10:36 AM. |
These two pics show the clearance on the super panhard bar from ECE. I don't think you would be able to sit the tube all the way into the notch with only a 1-1/2" block, There is less than 3/8" of clearance between mine and the frame.
Steven,
Thanks for the pictures. I finally got mine completed tonight. I'll try to snap some photo's tomorrow. Rob
I had to leave town today for a couple of weeks, so I still need to get the shorter bolts, put springs back in and put the bed on. I guess I'll finally get to see what it looks like a couple of days before Christmas.
Send me some pics. Where's Crowley at?
Rob
#13 |
Crowley is about 20 miles West of Lafayette. What do you want pics of?
#14 |
Your truck when you get it put back together.
R
#15 |
Oh, Yeah, of course. It should level my truck out a little better. I had a 4.5/6 drop but my front tires are 26" tall with 29" tall rear tires.
you got any pics of yours?
#16 |
I'll try to post some tomorrow.
r
#17 |
Hart Rob, any pics yet?
Brandon project 67 swb bagged on 20" Coddingtons |
#18 |
Here are some pics (better ones to come later):
#19 |
That looks good Rob! You're making me jealous... Maybe I can convince the wifey that I've been a good enough boy to get some bags for Christmas.
![]() I noticed your 48 is for sale, what'cha asking for it? My brother has been looking for one for awhile.
#20 |
Front tires are 25.5, rears are 28. After I get the body work done and the new engine (5.3/4L60E), I'll probably put a set of 20's on it.
Here's a link to my 48: http://67-72chevytrucks.com/vboard/s...70#post1462570 http://www.gaspumpclassics.com/find/...OGZWYX1MZYB1VF Let me know. Rob
#21 | |
Seņor Member
#22 |
I installed 2" lowering blocks when I installed the c-notch. I put the ECE bracket below the lowering block and used the bottom hole. It is close but it doesn't hit the notch/frame when lowered. I may trim the ECE bracket to get a little more clearance, but so far it hasn't been a problem.
Rob
#23 |
LAIDOUT
I modified my ECE bracket by adding two side plates to move the mounting hole down approximately 2.5", fixed the clearance issues.
#24 |
BigSky,
I would like to see some pics of your modifications. Rob
#25 |
LAIDOUT
Ok, here is what I did. In the photo you can see the rear side plate I added, plus where I had to trim the corner off the bracket. This is before I added 2" blocks and ran new brake lines behind the axle.
![]() I made this simple drawing of what I did. Imagine the view as looking from the differential towards the ECE bracket as installed. ![]() |
