Old 12-05-2005, 04:56 AM   #1
Americanrider
Question Hand throttle hook up?
I just got a 67/68 OE dash hand throttle cable and would like to see pics of a stock setup where it hooks into the carb linkage and where it passes through the firewall. Also like to know which knob is on top of the right side when you have both? The choke or the throttle.
If anyone has pics of this hooked into a 67 w/2brl solid linkage that would be even better.
Thanks,
Americanrider is offline   Reply With Quote
Old 12-05-2005, 10:48 AM   #2
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Re: Hand throttle hook up?
Choke cable is on top, Throttle is on bottom. The 1967 pickup I'm buying has this option, but I don't have pictures of the engine. Probably won't venture out to see it again for a couple of weeks.
more later
Justin
boundstaffpress is offline   Reply With Quote
Old 12-05-2005, 01:59 PM   #3
Coleman
Coleman's Avatar
Not sure if this helps but my 68 K20 has this option.
Coleman is offline   Reply With Quote
Old 12-05-2005, 02:25 PM   #4
Bob Moore
Coleman shows a very correct early hand throttle set-up. A bracket bolts onto the "normal" arm and the moveable portion of the cable extends through the bracket hole and is secured with a brass stop that has a set screw. The bracket allows the cable to float freely as you step on the gas pedal. Only when you use the hand cable does the cable retract and pull on the linkage rod to the carb.
When using a hand throttle on 71/72(cable style) the hand throttle cable mounts to holes on the inside bracketry down by your feet.
There is a dimple on the firewall that indicates where the cable comes through on the 67-70 models. The cable sheath must be secured at the firewall to work properly.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-07-2005, 04:06 AM   #5
Americanrider
Thanks to everyone who replied here.... looks like I have to go out and hunt up this bracket part now before I can make it work.
Old 01-13-2006, 02:16 PM   #6
boundstaffpress
American rider Have you had any luck assymbling your hand throttle? I went to pull mine out last nite, and the handle and shaft pulled clear out not attached to any cable.
Does anyone have pics of what the underdash setup looks like?
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
Old 01-23-2007, 09:05 PM   #7
breeh
Recovering 67-72 Addict
breeh's Avatar
Here are some more pics. Coleman, I can't quite see how the bracket attaches to the throttle rod. Does the little bolt and nut go through a hole in the throttle arm somewhere?
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 04-16-2007, 11:45 PM   #8
Coleman
Coleman's Avatar
Sorry, haven't been around for a while, I'll take more pics to try and help out. My 68 k20 is pretty much stock, pulled this truck out of the weeds a few years ago, everything seems to be the original setup.
68 Chevy K20
72 Chevy K20 (new)
2000 Silverado Z71
Old 04-17-2007, 01:21 AM   #9
Bob Moore
breeh - yes - you are correct. The small nut and bolt hold the bracket to the arm.
vac, 454, T400
more to follow
