Old 12-05-2005, 12:08 PM   #1
greenvilledave
yes there are stupied questions
and here is one how do you get the damn black handle off of the light switch does it pull off or screw off thanks don't want to break it dave
greenvilledave is offline   Reply With Quote
Old 12-05-2005, 12:18 PM   #2
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: yes there are stupied questions
Seems to me that there is a release button on the back of the switch and the whole rod comes out. Been about 8 yrs since i have messed with it though.
chevyguy_72 is offline   Reply With Quote
Old 12-05-2005, 12:20 PM   #3
chevyfarmer
chevyfarmer's Avatar
yes there is a release button on the actual switch, push it down and the plastic handle and the rod slide right out.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 12-05-2005, 12:50 PM   #4
greenvilledave
ok i will try it tonight thanks guys
Old 12-05-2005, 01:30 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
More detail...
Pull the lights switch on, then depress the button, and pull the knob and shaft out. You can't just push the button and pull.
Old 12-05-2005, 01:33 PM   #6
mrein3
mrein3's Avatar
Even more detail...
The button is on TOP of the switch.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-05-2005, 02:04 PM   #7
Hutch
Hutch's Avatar
greenvilledave
GMC Pauls web-site has a nice write-up in his tips section.
You will find it about half-way down the page.
While you are there check out the great stuff you can get from one of the supporting vendors.
http://www.gmcpauls.com/Tech%20Tips1.htm
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-05-2005, 05:01 PM   #8
Metmanice
Metmanice's Avatar
If is is still stuck consider using the cuttin' torch...works every time...
'67 C10 SWB Frame off (and smiling)
Metmanice is offline   Reply With Quote
Old 12-05-2005, 05:15 PM   #9
matthufham
http://67-72chevytrucks.com/vboard/s...32#post1332032
see topic
matthufham is offline   Reply With Quote
Old 12-05-2005, 07:52 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget to disconnect the battery... your lights will be on.
Old 12-05-2005, 08:35 PM   #11
GloryHound
Working on a Nova.
GloryHound's Avatar
Here is a picture and I am pointing at the button.
GloryHound is offline   Reply With Quote
Old 12-05-2005, 09:51 PM   #12
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I never pushed a button to get mine off. I did kinda a pull twist thing and it came off. Then when you unplug the wires to it the lights go out.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 12-07-2005, 02:24 PM   #13
greenvilledave
this is why i like to ask for help it's amazing how easy things are when you know what you are doing thanks alot dave
