Old 12-05-2005, 09:01 PM   #1
Scott Norris
Fast steering box?
Does anyone Know of a fast ratio power steering box that will interchange,or know of anyone that will rebuild ours?
Scott Norris is offline   Reply With Quote
Old 12-05-2005, 09:06 PM   #2
bisquik65
bisquik65's Avatar
Re: Fast steering box?
Simply get one off a 67-72 3/4 or 1 ton....1 1/2 turns lock to lock...and works great....almost to easy...
bisquik65 is offline   Reply With Quote
Old 12-05-2005, 09:06 PM   #3
RANDY COX
RANDY COX's Avatar
I used a box from an 83 blazer.bolt on
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-05-2005, 09:10 PM   #4
dennislbrooks
dennislbrooks's Avatar
is the 3/4 ton gear have the same 3/4" splined shaft? Are the pump lines the same as a1/2 ton? I like the way you guys think.
dennislbrooks is offline   Reply With Quote
Old 12-05-2005, 09:20 PM   #5
dennislbrooks
Rockauto shows the 83 with a 3/4" shaft with metric o-ring fittings. The 67-72 3/4 ton has IFF fittings but is 13/16" on the shaft spline unlike my 67. hmmm
Old 12-05-2005, 09:24 PM   #6
bisquik65
bisquik65's Avatar
Yes its a bolt on item...Everything the same....I have one on my 70 2wd blazer and like i said..its allmost too easy....very fast....to turn....
Old 12-05-2005, 09:26 PM   #7
bisquik65
bisquik65's Avatar
I have the lower column to fit the 3/4 boxes here,no boxes ...Maybe later i will get more...
Old 12-05-2005, 10:35 PM   #8
Bubba4spd
Bubba4spd's Avatar
This is great news guys. I have a 68 swb stepper with a 72 3/4 ton parts truck. Dang Im in good shape! Great post guys.
Bubba4spd is offline   Reply With Quote
Old 12-05-2005, 11:07 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
neither my one ton nor my 3/4 ton had quick ratio steering, and my 1/2 ton had the same ratio.
I have always been told that they were all one and the same. I don't think I've ever driven a truck that had more than 1 1/2 turns lock to lock onless it had manual steering.
The later trucks had variable rate steering... but it wasn't a quick ratio box.
Our truck boxes mount on the outside of the frame, while car boxes mount inside the frame... to my knowledge, there is no junk yard quick ratio swap for us.
The aftermarket on the otherhend... I'm sure they can hook you up, or even a local steering gear box place.... when my dad took the old Town Car to steer and gear here in columbus, he told them it steered too slow, so they hooked him up. Used the original box, new guts, very responsive now.
Old 12-05-2005, 11:20 PM   #10
see ten
WTB this ad
see ten's Avatar
I have an ECE quick ratio box on my C10. It took a full turn out lock to lock. Not cheap, but it works like it should.
see ten is offline   Reply With Quote
Old 12-05-2005, 11:31 PM   #11
Bob Moore
IIR the 69-72 PS boxes are about 4 1/4 turns lock to lock. The 73+ PS boxes are about 3 1/4 turns lock to lock. I recall asking a board member with an ECE "quick box" about lock to lock and being told 3+a little. The rag joint does change but that can't be to hard to buy the correct one.
I wonder about swapping internals from a Camaro/TransamFirebird box to get around a 2 1/2 lock to lock. Any body done this?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-06-2005, 02:39 AM   #12
rwgregory
Contact Wes at Classic Heartbeat in Olympia, WA. He is a dealer for "Red Cap" quick- ratio steering boxes.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 12-06-2005, 04:07 AM   #13
71RestoRod
71RestoRod's Avatar
I have a variable ratio box in mine... it's about 3 1/4 lock to lock. Custom built by Tregg Wright at Durex 800-862-6658. Total bolt in.. rag joint and all. Again... not cheap. He was a little hesitant about my mounting it in a 4x4 but the variable ratio is not too sensitive at all IMO. Works great.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 12-06-2005, 04:19 AM   #14
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Go back and read Bob Moore's post...there is the simple answer. Manual box =5.5 turns, 68-72 = 4.5 turns and the 73-? are 3.5. We call that a quick ratio and the used boxes are cheap. Just find a tight one.
I just put one in the 67 GMC that I was posting pics and updates on the pic board. Nice improvement with a big stock steering wheel.
PICKMUP is offline   Reply With Quote
Old 12-06-2005, 09:31 AM   #15
72MARIO
72MARIO's Avatar
I have one on my 67 from a 71 C20 it's feeels like 10 turn lock to lock. I am going to take the one off my 84 and put it on my 67 it is a really tight and takes alot less turns to get where I want to go.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-06-2005, 06:11 PM   #16
see ten
WTB this ad
see ten's Avatar
Won't you have to use metric lines for the 84 box?
Old 12-06-2005, 06:38 PM   #17
72MARIO
72MARIO's Avatar
Sure it might need diffirent lines but Metric lines wont bother me.
Anyone know what year they went to metric lines ?
2005 TAHOE DD
Old 12-06-2005, 06:51 PM   #18
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
I have the quick ratio box on mine since it is a 3/4 ton and it was obvious the cornering differece it had then. When I put all of this suspension and drivtrain on a shortbed frame it damn near got away from me. I can get the tires smoking on this and cut the wheel and the driver's front tire will spin on it's own axis. THAT'S AWESOME!
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 12-06-2005, 07:08 PM   #19
crazy longhorn
Fabricate till you "puke"
Maybe Im gettin old, so if you splain that in regler old dum dum terms......does that mean it likes to do doughnuts? crazyL...just razzin you
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-06-2005, 07:11 PM   #20
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We are having quick ratio steering gears remanufactured (by Read Head Steering Gears) with all new oversized bearings for added strength. They also custom fit each worm and piston assembly with special ordered precise oversized ball bearings. Again for longer life. We have them make our gears special order for our trucks. This way they have the same input shaft as our trucks do and the same power steering hose fittings also. The only difference is that they are 3 1/2 turns lock to lock instead of the 4 1/2 that our trucks both the 1/2 tons and 3/4 tons have. Our gears also come with a 12 month unlimited milage guarantee!! Lets see a junk yard give you that. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-06-2005, 07:13 PM   #21
bisquik65
bisquik65's Avatar
My box came off a 71 3/4 camper specail with a 350 2wd...1 1/2 turns to the left,1 1/2 turns to the right...super fast box...
Old 12-06-2005, 07:17 PM   #22
72MARIO
72MARIO's Avatar
Oky how small is you steering wheel ?
2005 TAHOE DD
Old 12-06-2005, 07:24 PM   #23
bisquik65
bisquik65's Avatar
Stock 70 wheel
Old 12-06-2005, 07:25 PM   #24
crazy longhorn
The size of the wheel shouldnt make a difff on "lock to lock", but the smaller wheels are less distance to turn. I run an 84 burb (metric box) on my longhorn, & count 3 1/4 turns lock to lock...... L
Old 12-06-2005, 07:47 PM   #25
Classic Heartbeat
Hmmmm... My 71 Copper 3/4 ton Copper Truck is 4 1/2 same as my Orange 3/4 ton Cheyenne Super. The GM master parts catolog only gives one part number for the series 10 thru 30 steering gears also. Wonder what the deal is on that.. Something else to ponder...lol WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
