Old 12-05-2005, 09:29 PM   #1
1967k30
1967k30's Avatar
88-98 seats or 99'-05' seats
How do 88-98 40/20/40 seats fit in our 67'-72' trucks? How about 99'-05' buckets? I found a nice leather one out of a 98' and was just what I want but I wanted to check and see how it would fit first.Thanks in advance
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 12-05-2005, 10:10 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 88-98 seats or 99'-05' seats
They fit like they're made for them. I want a 96-98 40/20/40 seat for my truck, but bought a 98 Tahoe/Suburban 2nd row seat in tan leather....because the price was right. Several of the board members have used this seat, and they look nice. They can't be adjusted, because they have no track. So, that's the down side. But, the seat bottoms can be pivoted upward, to reveal some handy-dandy storage space that you may need in the future. Add to that, the fact that they have seat backs which fold forward and also have a panel that will serve to hide the gas tank, in case you haven't relocated yours outside of the cab.
But, I really prefer the 40/20/40 seat.
Member Nr. 2770
Old 12-05-2005, 10:43 PM   #3
yank
yank's Avatar
I just got seat like ChevloRay has. After I seen Putter's and Gman69's seats in there trucks that's what I went out and got.
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline   Reply With Quote
Old 12-05-2005, 11:49 PM   #4
I prefer the 88-98 style seats over the newer ones myself. I'm doing buckets though. They are from a 97 and will go in my 69 when I get the new cab ready to put on it.
Old 12-05-2005, 11:59 PM   #5
1967k30
1967k30's Avatar
I had wondered about Sub/Tahoe rear seats.They are usurally cheap,which is better.I'll see what I can work out on this front seat and if it doesn't work I may grab a rear seat.How close are the factory holes? Did you just drill new holes on the seat frame?
Old 12-06-2005, 12:03 AM   #6
davidh
davidh's Avatar
I Have a 89 or so seat, just a bench. I noticed the front holes line up but the back ones do not. And it sits too low. Any ideas?
davidh is offline   Reply With Quote
Old 12-06-2005, 09:17 AM   #7
72MARIO
72MARIO's Avatar
Here is mine it's from a 98.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-06-2005, 10:12 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Guess I'll chime in. I like the older seats because the seat back is a little lower and doesn't look big and goofy in the back window. I think the newer buckets cover a good bit of the back window. I have a 93 split bench in my truck. I like it a lot. THe headrests are small and the seat back is right at the bottom of the window.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-06-2005, 10:21 AM   #9
Putter
More Cowbell....
Putter's Avatar
Ditto on the '99 Suburban second rows. Same seats in original cab, and now in the replacement cab....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-06-2005, 12:54 PM   #10
724wdcopper
graphic designer
724wdcopper's Avatar
hey, 1967k30... i'd take a real close look at putter's last pic. your sig mentions you have a 4wd, so that usually means high hump (unless you've swapped it) and in putter's pic, looks like a high hump would prevent these seats from working. proceed with caution.
724wdcopper is offline   Reply With Quote
Old 12-06-2005, 01:27 PM   #11
Coleman
Coleman's Avatar
So what is the option for a high hump 4x4. Has anyone "been there done that"?
Coleman is offline   Reply With Quote
Old 12-06-2005, 01:56 PM   #12
88-98 front bench/buckets, not the second row seats.
Old 12-06-2005, 03:39 PM   #13
1967k30
1967k30's Avatar
Thanks for pointing that out.It doesn't look like a rear seat will work on a 4x4 or big hump truck.It seems that a 88'-98' front should.I had an 88'and a 97' and I think either seat would have worked.But just to be sure does anyone have a pic of a 4x4 with a 96+ 40/20/40 seat?
Old 12-06-2005, 04:18 PM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here are 40/20/40 *edit they are probably 1999, not 1998, Silverado seats that I have in my K20.
I am now using a low hump but when I mocked them up there was no interference with the high hump. I re-enforced the floor top and bottom to hopefully make the integrated seatbelts safe in relation to the floor.
These seats sit you a touch higher and definitely closer to the dash. I don't have the gas tank behind the seats but that doesn't matter with how they sit. I am right at 6' and anyone taller might feel too cramped. I have the seat backs fairly straight to give me extra leg length. I like the seats, they are very comortable to me.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-06-2005, 05:48 PM   #15
DangerBoy
I picked up a set of nice lookin buckets and got lucky on them. The hole spacing front to back is the same as the 67-72 trucks. So I got my hands on another set of seat brackets and made a plate to go across the part that has 2 holes on the front They fit good and look pretty bad ass. As promised before, pictures will come as soon as I remember to get my camera.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 12-06-2005, 06:31 PM   #16
weasel29gm
SLOW BUT SURE,BUT CLOSER
Late model seats are one of the best mods you can do.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 12-06-2005, 11:00 PM   #17
72Short_Cut
72Short_Cut's Avatar
Did you change the bottom brackets at all,lowering them?
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline   Reply With Quote
Old 12-06-2005, 11:47 PM   #18
No, I mounted the stock brackets in the outer two stock front holes. Then I made a plate that nolted t the back two seat holes and extended forward to under where the newer brackest are. Drilled a hole through the bracket and floor, added a spacer (I used a 3/4-1/2 Plumper's Joiner Bushing- See second picture). Secrured with Grade 8 bolts and large washers under the floor panel. Now drive in comfort!!!
Old 12-06-2005, 11:51 PM   #19
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Some Great looking seats in here . This is a 98 Silverado 60/40
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-07-2005, 12:20 AM   #20
muddpile
muddpile's Avatar
Palf70Step, is that how everybody mounts the 88+ seats? I bought a set of 92 (I think) buckets and console, and have not mounted them yet, but they seem to fit nice with the seat slid all the way forward, and the bracket down behind that hump in the middle of the floor. I'd have to reinforce all 8 bolts and drill all new holes, but that doesn't bother me. Has anyone else done it this way?
muddpile is offline   Reply With Quote
Old 12-07-2005, 12:46 AM   #21
1967k30
1967k30's Avatar
I meant 40/60 is what I'm looking at,my bad.Those all look like they fit pretty good.Right now I have an 80' seat in mine and it didn't fit worth a crap.Had to fab all new brackets and it sits too close to the dash. I have the fuel tank behind the seat still and will probably leave it there but not sure yet.
Old 12-07-2005, 12:54 AM   #22
72MARIO
72MARIO's Avatar
How do the 60/40 seats fit in your truck ? Were they a fairly somple bolt in ? I found a 89 with the same seat in it. Somone must have swaped a newer seat into the 89 but it's the seat I originally wanted.
2005 TAHOE DD
Old 12-07-2005, 02:15 AM   #23
jsbgump
Gone Fishing
jsbgump's Avatar
I am actually running a set of those but in blue. They are very comfortable to ride around in.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 12-07-2005, 06:27 AM   #24
They are about the same. Check out my web site, interrior pages. I had a set in mine for a bit.
Mudpile...no some mount them the way you say on the flat of the floor. You'll need to do more bracing (IMO) if you do it that way.
Old 12-07-2005, 11:31 AM   #25
Bill72BB
Bill72BB's Avatar
Too many Bill's in here
BILL
Member DUF Club
