front end swap
Hi all, I am working on a 67 C10 stepside that came factory 6cyl 3 on the tree. I will most likely be running a 327/350 hydro. I have a 85 GMC parts truck that I would like to use the disk brakes and rear end (411 gears are horrible on gas) I need to know if I can use the entire frond end from spindle to spindle including the crossmember. I think it should work but I really need to be know before I take my truck apart. should I just use the spindles and forget the rest? Any help is greatly needed.
Thank you, G_Goble |
Designated A-hole!
Re: front end swap
Welcome to the board from South Mississippi. You can use the entire crossmember, it's a cheap way to upgrade your brakes. I'm about to do the same thing myself. Check out our FAQ board for lots of good info.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: front end swap
Thanks for the info. I'll start working on it this weekend.
Post Whore
![]() Join Date: Feb 2000
Re: front end swap
Welcome - keep us posted on your project.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Active Member
Re: front end swap
welcome from Orlando
Catchy title goes here..
![]() Join Date: Mar 2002
Re: front end swap
Gone Fishing
Re: front end swap
welcome from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
