Turbo Guy
crossmember swap
I'm sure this one has been done a million times, but I have looked and can't seem to find a definitive answer, could anyone please help me I don't want to assemble a newly painted truck and have it unable to be alligned. I have a 71 c10 2wd with 73-87 lowered spindles a 73-87 cross link pitman, idler arm, and tie rods, and 73-87 upper ball joint in the 71 a-frame and a stock ball joint in the 71 lower a-frame. Everything bolts together and works but I have not had it alligned, other than a tape measure(drives not bad actually). I am starting dissasembly to put the truck into paint and have found the steel bushings in the a-frames to be completely worn out. I have a set of upper and lower a-frames from 73-87 with rubber bushing and wish to install them. Everything I find has talk of swapping the entire crossmember, is this nescessary to get a proper allignment? Or can I just swap all the parts. I looked quick but the croosmembers look to be the same. Any and all help is appreciated thanks.
Fabricate till you "puke"
Re: crossmember swap
I think you can swap the later arms onto your crossmember......that IS NOT a definative answer tho! I am running the same setup you currently have (73+ spindles & linkage, with the stock 69 crossmember & a a rms). IMO, the early steel bushed arms are the best way to go(no flex). Are your arms worn from the bushings being really bad? just for thought..... it will be a little more expense to replace the shafts & bushings, but i have seen the steel bushings last 1/4 million miles (if greased now & then)....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Turbo Guy
Yours does line up though? As in you have had a proffessional allignment? A friend of mine told me all this will have trouble alligning, the reason for my questions now. thanks
Turbo Guy
Any help? Should I change the crossmember?
My truck hasnt been into the shop for alignment, I just gave her a "backyard alignment" (rough bubble check on the camber, & set the toe with a tape). it drives good, & after 10,000 mi I dont see any odd tire wear. I dont think a shop alignment wound be an issue......the reason that guys are swapping the complete crossmember is , that way they dont have to guess what parts fit together. You have already got the pcs to fit/work......
I have a '67 C10 1/2 ton that is my daily driver (126 miles each day) and I only know what I did and I didn't have any problems getting the alignment done. I left my crossmember in, changed the upper and lower control arms, ball joints and spindles, pitman arm, tie rods and linkages from a '83 C10. She now rides sweet and straight. But I do agree with "crazy longhorn", it's a lot easier if you can change everything as a unit instead of mixing and matching. Good luck.
Turbo Guy
Thanks guys that puts my fears to rest
Out of the carpool lane.
You absolutely DO NOT have to swap the crossmember itself. I have the entire fe from a 77 sans the actual crossmember. However, I kinda wish I had swapped the crossmember also only because it uses thicker u bolts to hold the control arms on, but that's a very minor cosmetic thing.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
brad, you are correct that it does give you the chance to use the thicker "u" bolts...all i did was drill the four holes larger and problem solved. I am by far no genius, I get all my info from these extremely experienced group of experts.
![]() Join Date: Mar 2001
GM still sells the front crossmember U-bolts for the lower A-Arm. My originals were 1/2" and the replacements were 9/16" They fit into the stock crossmember without any drilling required. I also purchased machine grade flat washers (really thick) and GR-8 compression nuts.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
