Later year wheels?
I have a guy who is selling his 20" wheels off of his 2000 Yukon. Will they fit with out any problems on my 6 lug. Will the back spacing be a problem? I have front disc on my 68 now.
68 Chevy short wide air cab 4/6 on the drop 327 small block Front disc Frame "c" sectioned Gaylord bed cover |
Re: Later year wheels?
More than likely the back spacing will be a problem. I had to put wheel spacer on mine to get them to fit (18" Budnick wheels that came off a late model truck).
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
So what is the proper back spacing measurements for stock then? So does this mean that they will rub on the inside as you turn?
Old Skool Club
![]() Join Date: Jun 2001
ECE (Early Classic Enterprises) says anything larger than 15-inch diameter, can be 4.5-inch back space. If they're 15-inch, then 4-inch backspace is the max.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I bought a set of 20's from a new Silverado. You will need to run spacers to get them to fit. Also the hub size in the back will not allow the wheel to be mounted without a spacer or machining of the hub of the axle.
Brandon project 67 swb bagged on 20" Coddingtons |
#6 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
1.5 spacer? Wow. Thought it was going to be easy. The guy wants to sell his custom wheels before trading in the yukon, so I can get them pretty reasonable. I know to have a set made with the correct back spacing cost an arm and a leg.
Yeah, that's why I decided to just run the spacers. My truck's not a daily driver so I'm not too concerned about them. If you go this route, just make sure you torque everything down good, then re-torque everything about 100 miles later just to be on the safe side.
riden2low sent you a PM
