12-06-2005, 04:27 PM | #1 |
Certified Pud Puller
FNG needs help!
how come i cant find 3" drop spindles for my 72? did they stop making them or something i can only find 2.5 does anyone know a site or place that has them or anyone with a spare set. also is there anyone around the MD VA area who has experience with frame mods like back halfing Zing and all that good stuff that could possibly lend a hand?
1997 Silverado extended cab- mpfi conversion, 22" kmc's 1983 C10- some assembly required 99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s |
12-06-2005, 04:40 PM | #2 |
Re: FNG needs help!
they make 3 inch dropped spindles for a 73 and up ....you dont have to change much to run them .......
12-06-2005, 05:25 PM | #3 | |
Fabricate till you "puke"
Re: FNG needs help!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-06-2005, 06:40 PM | #4 |
67-72 parts collector,…
Re: FNG needs help!
Use the 3" Belltech '73-up spindles. If your truck is a '71-'72 all you need to change is the upper ball joint and the outer tie rod ends. If its a '67-'70 you will need to change BOTH upper and lower ball joints,...AND,... either use a conversion outer tie rod end,... or run a '71-'72 centerlink, inner tie rod, and '73-up outer tie rod. Hope thats not too confusing. I've done this and it works great.
12-06-2005, 08:41 PM | #5 |
Re: FNG needs help!
[URL="http://store.streetbeatcustoms.com/bel3120.html yay i found them for 71-72
12-08-2005, 06:51 AM | #6 |
Re: FNG needs help!
ttt
12-11-2005, 02:21 PM | #7 |
Watch out for your cornhole !
Re: FNG needs help!
Here is a Belltech 3 inch drop spindle specifically for 71-72 trucks. No ball joint or tie rod changes required.
http://store.summitracing.com/partde...3&autoview=sku
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-11-2005 at 02:22 PM. |
12-24-2005, 05:13 PM | #8 |
laying low
Re: FNG needs help!
Isn't it mandatory to run large diameter wheels with the 3" spindles? Minimum of 17" or something like that?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-24-2005, 05:23 PM | #9 |
Re: FNG needs help!
I called Belltech a while back about the 3" spindle. They stated it is usually not necessary to run a larger rim. The most you may need to do is clearance the lower control arm a bit.
I am running 15x8 front and rear and will be going over to the 3" spindles after the holidays. ($I hope$) I am planning on going over to 20" rims down the road though. |
12-24-2005, 06:21 PM | #10 |
Re: FNG needs help!
I run a 3 inch Belltech spindle set on my Blazer with 15 inch rally wheels. The wheel rubbed the control arm a lot. I mean a whole lot. I have had to clearance the lower arm before on other trucks with 2.5 inch spindles, but it was nothing like this was. I wound up running a pair of 7 inch wheels on the front.
12-24-2005, 09:42 PM | #11 |
Re: FNG needs help!
i put my nice new drop spindles on yesterday thanks tx firefighter and the lower control arm does rub the rim when its up but when i let it down it doesnt
