07-12-2002, 01:36 PM | #1 |
Pulling distributor....I got an idea.
I got everyting ready to swap manifolds. I was thinking yesterday about the distributor, and how to pull it and replace it without loosing my timing. In other words I want the distributor to go back in in EXACTLY the same place it was when I pulled it. Since I haven't done this before EVER I started brainstorming.
Why not take a straight edge, and lay it across the distributor in between the terminals (mark the terminals of course) so that it points to a spot on the firewall, and then just make a mark on the firewall with some white wax pencil or something? That way when I put the distributor back in I just put the straight-edge back where it was and move the distributor until it lines up with the mark?!? Good idea? I think so. If not please correct my fuzzy math.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
07-12-2002, 02:05 PM | #2 |
user # 2756
I do the same thing but use tape. Also remeber the distributor will turn slightly when you take it out. So when you put it back in start with a slight turn and it will rotate back to where it was.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-12-2002, 02:11 PM | #3 |
That's what I do too, and also mark the base of the dist. at the intake, so you will be close on the timing setting.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
07-12-2002, 02:22 PM | #4 |
CCRider
Don't be chicken!!!!!! Pull the spark wires off without marking them. Pull the distributor without looking at which way the rotor is pointed. Now you have no choice but to learn how to time a motor. Once you ever learn how, it takes less time than marking all that stuff. Good Luck
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
07-12-2002, 03:48 PM | #5 |
Um...I know how to time a motor. Specifically, I know how to time this one and it was a huge pain in the ass. I don't want to screw with it again for a while, and I just did it a couple of weeks ago.
Problem is the 327 manifold on this 350 is difficult to balance without a horrible hesitation. I had to advance it quite a bit to get it accelerating smooth. Thanks. Nice to know my ideas aren't totally dumb.
07-12-2002, 03:48 PM | #6 |
Between Trucks...
i'll second that...
dude, get a timing light...
Beat it to fit, Paint it to match... |
07-12-2002, 03:54 PM | #7 |
Like I just said. Dude, I got one.
07-12-2002, 04:01 PM | #8 |
Dude, that's good.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
07-12-2002, 05:08 PM | #9 |
its all about the +6 inches
I mark mine to the manifold, or in your case, to the fire wall, then i also mak the rotor to the distributer body once it had turned.
Then I line up the rotor to the mark, drop it in, and line up the other mark. Don't even need to get out the T-light. |
07-12-2002, 06:49 PM | #10 |
IMHO your spending more time then it would take to time it.
But that was not your question and the suggestions given seem to be your answer. |
07-12-2002, 06:59 PM | #11 |
Well, my real issue is that I spent forever trying to get good timing on this engine even with a timing gun on #1 wire. I know I could get it back, but I'd rather have a simple mark that saves me the trouble of trying to find out where that magical spot is on the damper that allows good solid acceleration without hesitation (which is what I had at 8 degrees -- where it was initially set). Now it's as far advanced as I can get away with, and it seems to be performing very well. Any more advance and my engine won't idle very well. Any less and my engine wants to hesitate badly when I give it stiff throttle...
I'm sure if I had a good intake/engine combo in the first place I wouldn't have this problem. Since I'm swapping identical intakes it seems logical that my timing would be exactly the same, but we'll see...
07-12-2002, 07:25 PM | #12 |
CCRider
Well maybe this will make you feel better. I have had at least 20 smallblock Chevys, and out of the 20 I have had maybe 3 that you could set on 8 degrees btdc and they would run right. Most of them I have had to advance the timing till it was completely off the timing tab to get them to run right. Now most of these motors were used and who knows what kind of mismatched parts I was dealing with, but it has got me to the point where I don't even use a timing light. I aways just advance the timing till it "pings" under full throttle, then retard it till it just stops. If the starter doesn't kickback with this setting thats how I run it. I bet my timing light has 2" of dust on it. lol
07-12-2002, 07:38 PM | #13 |
lol
Yeah, that sounds about what I'm dealing with. The mark is literally 3" left of the indicator strip at least. I finally gave up on the light after a while, and just turned the distrubutor until I got good acceleration. Then I ran out of room, so I had to move the plugs over one terminal so the vaccum advance wasn't sitting against the manifold, and repeated the process of getting good timing. THEN I went and checked it with the timing gun to see where the marked ended up. Damn, it was almost on the passenger's side of the damper.
07-12-2002, 08:05 PM | #14 |
Between Trucks...
well, perdon moi,
that's how people who don't speak mexican talk in L.A ...
07-12-2002, 08:43 PM | #15 |
Formerly yellow72custom
The 350 in my truck runs the best at 11 degrees BTDC. I tried to advance it to 12, but i got a spark knock when pulling hills. What kind of a intake/carb are you swapping on to your motor?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
07-12-2002, 08:58 PM | #16 |
Between Trucks...
i found on my 72, if you advance the pi$$ out of it, like pass the timing marker around 9 or 10'clock, that it was quicker off the line, but i couldn't get any top end, only to about 100 mph...
i backed it off to about 12-15 degrees, so i can bury the speedo... P.S. that's how people talk down here dude...
07-12-2002, 11:04 PM | #17 |
DUDE! whats mine say?!?
07-12-2002, 11:08 PM | #18 |
SWEET!!! What's mine say?
07-12-2002, 11:36 PM | #19 |
DUDE!!
07-13-2002, 12:29 AM | #20 | |
Bloo
DUDE!! Wheres my truck?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-13-2002, 01:58 AM | #21 |
Between Trucks...
that's exactly how people are here it's scary...
