Old 12-07-2005, 06:57 AM   #1
J-Rod
GMC Dreamer
J-Rod's Avatar
Rear spring lowering info
Just wonderin how much of the coil I have to cut to get about 2 in. lower in the rear.
J-Rod is offline   Reply With Quote
Old 12-07-2005, 08:13 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Rear spring lowering info
You can't cut rear springs.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-07-2005, 09:16 AM   #3
crazy longhorn
Fabricate till you "puke"
If all you want is a 2" drop, a 2" set of blocks & longer U bolts should do the trick....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-07-2005, 01:28 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Just buy some lowering springs and be done w/ it. They're only $100. Check out Early Classic, McGaughy's, or CPP. They all have quality stuff. You can't cut the rear springs like the fronts since the springs are tapered on each end. You wound't be able to fit the spring into the mounting plate if you cut them.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
