Old 07-12-2002, 02:33 PM   #1
my67c20
Question Manual Transmission upgrade
I need some help. My 67 C20 has a 4 speed with granny low trans. However nice this might be for pulling out stumps it really does me no justice on RPM for freeway driving. I would like to switch this with another stick with overdrive. I really need to keep the cost low (under $700.00). I got some previous response suggesting the NV4500 but again waaay over my budget. Under no circumstances am i willing to put an automatic in. I really appreciate any help or suggestions on what will be the best choice. I have a 350 engine in the beast. Thanks
my67c20 is offline   Reply With Quote
Old 07-12-2002, 02:39 PM   #2
kaycee
kaycee's Avatar
Lightbulb
What size of rear gears do you have in it?You might think of a different gear setup.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 07-12-2002, 05:15 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Swapping in another 4 speed will not help your free way RPM's.
To do this, you will either need to get a 5 speed, replace your rear gears with a 3.07 or so, or, get some big 'ole friggen tires on the back.
Old 07-12-2002, 06:59 PM   #4
my67c20
Well that last thing i want to do is replace the rearend. However a 5 speed will still work. I am basically looking at doing the least to get the most.
Old 07-12-2002, 07:02 PM   #5
Longhorn Man
If you swap out the whole reare axle...the hardest part is bleeding the brakes.
Old 07-12-2002, 07:08 PM   #6
my67c20
I follow on the rearend. Unfortunatly for some odd reason coming across a complete rearend in california is not very easy. i would much rather prefer changing the trans. I need to get in there and replace the clutch but again the most for the least is what i am after.
Old 07-12-2002, 07:33 PM   #7
Huck
Huck's Avatar
Wink
Someone had an 82 Camaro 5 speed on the board for sale last week---. I put in a 96' truck 5 speed, with headers, HEI, Edelbrock, and a 308Posi--give me 22mpg on the flats. Paid $650 for the trans with everything to convert but the crossmember and getting the driveshaft resized. End result was well worth the trouble. Dropped about 100 lbs and gained about 6mpg. Love that 5th gear~~~~~~Huck
Huck is offline   Reply With Quote
Old 07-12-2002, 07:40 PM   #8
Huck
Huck's Avatar
JunkyardJohn has or had the 5speed---and it sounds like a great deal to me~~~~. Check it out on the 4sale thread.
Old 07-12-2002, 09:28 PM   #9
Longhorn Man
If you are running a stock engine, then the T5 is an ok tranny, if you drive her hard...it may scatter...there is a reason it was never put behinde a 350 from G.M.
Also, be warned that the tranny mount is not level on a Camaro one...I think it is 18 degrees off center, at an angle.
Old 07-13-2002, 12:13 AM   #10
ekelzo
Not too old for R n' R
If You use a T-5 From a camaro, you should get a camaro belhousing, which will put the shifter straight up. But be forewarned, the shifter will be approx. 4-5 inches into your bench seat. you'll need to fabricate a shifter to be comfotable, but it can be done, but only with buckets.
72 swb step L6 3sp driver / beater / project.
69 AMX 390 4sp. Big Bad Orange long term project.
ekelzo is offline   Reply With Quote
