![]() Join Date: Jul 2002
Fuel injection
Hi all.....have a 82 C-10 shortbed step 6 cylinder that I'm looking to put fuel injection on.....who provides kits for this set-up? Thanks....
Patch |
Re: Fuel injection
I've seen a few different versions, from Holley and Eldelbrack and I'm sure others. But they all seemed really expensive - like over $1000?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Re: Fuel injection
http://www.affordable-fuel-injection...evy-system.htm I don't know if this system is any good or not. I am starting to look into this, since I am planning on selling the 2005 and getting a 73-80 truck. Also how hard is it to use a tbi or multiport off of a later year?
STILL PLAYS WITH TRUX
It depends on what type of injection system you want to run.
It also depends on what type of 6 cylinder your talking about if you have a 4.3 V6 then its not too hard and if you have a I6 then it may be some what of a challange im not shure if theres any systems out there for an I6. Theres alot of kits out there and it all depends on what you want to run and how much you want or have to spend. That kit that jeff posted a link to looks really good and complete and its price is reasonable. Its gonna be really hard to get a complete kit for under a grand and thats what you need to go with since your truck is an '82 you will need to either run an external fuel pump or buy a fuel injection fuel tank. |
Re: Fuel injection
The cheapest kit might be a clapped out 87 pickup or 87-91 burb.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Fuel injection
If you are talking about the factory '82, you mean I6.
They are out there, but like was said, plan on spending at a minimum $1000. http://cliffordperformance.net/ has alot of I6 pieces including a TBI kit.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
![]() Join Date: Apr 2001
Re: Fuel injection
when i had my 250 i had thrownt he idea around to modify a older 4.0L Mopar injection system to fit our trucks... i think with a little milling and tapping, and some creative wiring placement it would work.. the displacements and compression/cam profiles are similar so i would think you could use the stock ECM... and since they are in a ton of jeeps, they would be affordable and there are some aftermarket upgrades available too... pls you can pick up an old clapped out jeep for less than 1000 bucks...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Re: Fuel injection
I posted this in your other post of the same title:
www.cliffordperformance.net has a TBI kit for I6's http://cliffordperformance.net/Merch...tegory_Code=FI Sissell's also have Port EFI http://www.sissellsautomotive.com/fuelinjection.html
Gentleman Jim Driver
Re: Fuel injection
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
