decoding rear axle codes
i have a code off a rearend i need decoded. looked like HA P8 19 or HA D819
i cant find the website i used to use for this im just trying to find out the gear ratio taht is in there
70 longbed 496/th400/Ford 9" |
Justascratch
Re: decoding rear axle codes
'67 - '70 3.08 non posi
justascratch-OKC,OK |
thanks. i thought i had looked it up beofre and it was 3.73 but i guess not... how do y ou find ur information website or book?
I use Hollanders myself..but there's an online page at
http://www.americanclassic.com/paint.htm and it says 373 for a 69 at least and I never looked it up in the Hollander yet.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 12-08-2005 at 10:29 PM. |
thats great if it is a 3.73!!!!! means i dont have to go buy another rearend... thanks rod. and thanks justascatch for trying!
its all about the +6 inches
Why not count the teeth...then you'll know for sure.
Things change in these trucks..people do all sorts of changes....pulling the cover is best...you'll get a look, and probably needs some fluid change anyway.
