Old 12-08-2005, 09:08 PM   #1
shelby987
shelby987's Avatar
cab corner replacement
Looking to replace my cab corners, this will be my first attempt at body panel replacement, which means that I need to buy some welding equipment.....can anyone point me in the right direction....mig, tig, arc......miller, lincoln, craftsmen, airco????
Would like something I can use around the house, for basic body panel replacement and maybe for boxing a frame or two down the road.
Any advice on what to get, and why would be appreciated.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 12-08-2005, 09:33 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: cab corner replacement
Mig with gas .023 wire -- one that will weld to about 3/16" thick --depends on what duty you need and how much you want to spend. There are many good brands. I have a CH Mig Flux 105. 75% Argon with 25% Carbon Dioxide. Get at least a 40 lb bottle. Your welding probably will be stitch - on and off on lowest setting. Auto dimming helmets are nice.
dennislbrooks is offline   Reply With Quote
Old 12-09-2005, 12:31 AM   #3
srv8800
i got a 220v lincoln 175 mig welder from lowes for around $600. even if you're just doing bodywork, i would still get a 220v welder. this way, you have the option of welding thicker stuff if needed. miller and lincoln are considered the best brands. a mig welder will suite your needs perfectly.
'72 lwb pickup daily driver
srv8800 is offline   Reply With Quote
Old 12-09-2005, 07:43 AM   #4
68cajun
68 C/10
68cajun's Avatar
I have the 220v 175 amp Hobart, and love it. I can weld aluminum, steel, and stainless steel. Paid 600 and think it the best 600 I have ever spent.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 12-09-2005, 11:22 AM   #5
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I got a 110 Lincoln squirt gun at Home Depot. $200 I think. NR211 innershield. Pretty handy little rascal. Not for thicker stuff over 1/4".
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 12-09-2005, 11:50 AM   #6
Huck
Huck's Avatar
My experience after taking a welding class and buying a cheapie wire feed welder is that it will blow right through the thin gauge sheet metal. You will need a wire feed with gas to prevent some of this. Practice a lot before you try it for real on your truck. BIG HINT --don't replace more sheet metal then what is shot!! Just because you get a complete cab corner you may only need to replace a smaller section. CAB CORNERS are a tough replacement because of all the curves and angles involved. I tried 3 from 3 different suppliers and not one fit perfect. In some cases you may be able to chemically stop the rust, then flush and treat with POR15 paint, then bondo over that and it will last for many years. Bondo is not a dirty word but one when properly utilized, can save lots of time and money. Just ask any good auto-body guy. You can also just spred the crap over rust which is the lazy fix and one that always comes back to bite you thus the bad rep. My .02
Huck is offline   Reply With Quote
Old 12-09-2005, 11:55 AM   #7
shifty
Questionable
shifty's Avatar
There's a great thread on welders at the top of the Auto Body forum (look at the forums list). You can glean a lot of info from it like I did. I was in the same position as you about 3 months ago.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
