Old 12-09-2005, 02:06 AM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Pics needed, I'm really close...
To getting to start the Blazer up and run the engine. I need some pics of the clutch linkage though. I have a stock 350 with a stock 4 speed, I think SM465. I need to make sure my linkage is right though. Could someone post pics of their linkage including the z-bar and return spring? I think any 4wd truck would work. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-09-2005, 02:00 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: Pics needed, I'm really close...
If I remember, I will get you a couple pics from the build book when I get home today. Work gets in my way sometimes.
dennislbrooks is offline   Reply With Quote
Old 12-09-2005, 05:16 PM   #3
red71cheyenne
Back in the sticks
Thanks Dennis. Ya, can't wait til I retire so work will be the trucks. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-09-2005, 06:28 PM   #4
dennislbrooks
Dang, I have not figured out the logical order of the build book - no index. Here is a pic of a right hand drive for a 6 cylinder--think in opposite. I will keep looking for the left hand V8. Will stumble across it someday.
Old 12-09-2005, 08:20 PM   #5
red71cheyenne
Back in the sticks
Duh, I have one of those, might ought to look at it. Thanks Dennis! Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-09-2005, 08:37 PM   #6
mudpuppie
mudpuppie's Avatar
was working on mine ...... 2 wd
mudpuppie is offline   Reply With Quote
Old 12-10-2005, 11:11 PM   #7
red71cheyenne
Back in the sticks
Sweet! Thanks Mudpuppie! Thats what I was looking for. Funny though, mine doesn't have that bracket that goes to the tranny bolt. Is your ball stud mounted to the engine? Mine is. Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-11-2005, 08:57 AM   #8
mudpuppie
mudpuppie's Avatar
Not konowing if its orignial , just what i have .......
Old 12-12-2005, 01:25 AM   #9
knsmodels
I make Models
knsmodels's Avatar
Red.....the 2wd is different than the 4wd.....like you said your ball stud is mounted to the engine block farther up without the bracket.....I will try and get you pics of mine tomorrow if no one else comes up with any.....LMC catalog has pretty good pics of the linkage if I remember correctly....Paul
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 12-12-2005, 02:56 PM   #10
red71cheyenne
Back in the sticks
kns, thanks ya, lmc shows some of the linkage, but not where the ball stud is on the engine or where the return spring goes. It doesn't show the bracket on mudpuppies setup either. I'm just wanting to make sure mine is hooked up right before I start it up and try to drive it down the road. The assembly manual is a little vague too, except on the 6 cyl. model. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-12-2005, 03:59 PM   #11
knsmodels
I make Models
knsmodels's Avatar
red......hope these help.......I had the inner fender out last week and that would have been the perfect time for pics.....but this is the best I can do....let me know if there is something specific you need to know....
Old 12-12-2005, 06:38 PM   #12
red71cheyenne
Back in the sticks
Those are perfect! That is exactly what I needed. By the way, sweet looking engine and exhaust! Looks like mine will look when I'm done. Is that a heat riser I see there?
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-12-2005, 11:21 PM   #13
knsmodels
I make Models
knsmodels's Avatar
red.....thanks for the comments.....just finished the truck in the beginning of the Summer.....it is pretty much stock so yeah that's the heat riser tube you see there.....Let me know if you need anything else.....
