Old 12-09-2005, 06:56 PM   #1
chevy lover
HMMMM Chevy
chevy lover's Avatar
front driveshaft woos
I recently put a sm465/205 behind my deisel. Problem was my front shaft is too long, so I got the shaft with the doners. It has a bad cv at the rear of the shaft. Is this something you can replace as a whole or must I take it apart to fix?
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
chevy lover is offline   Reply With Quote
Old 12-09-2005, 07:48 PM   #2
shilo
shilo's Avatar
Re: front driveshaft woos
If its the same as my truck, the ujoints are replaceable.
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 12-09-2005, 09:08 PM   #3
chevy lover
HMMMM Chevy
Big collar with 2 u-joints. I was hoping I could replace the whole thing.
Mike
Old 12-10-2005, 12:14 AM   #4
freightdriver
yes they're replaceable
freightdriver is offline   Reply With Quote
Old 12-11-2005, 08:53 PM   #5
454_72_4X4
454_72_4X4's Avatar
I think you'll have to take it to a drive shaft shop to have the entire CV replaced. If the ball pivot in the center is worn out that'd be best anyway. (Or get a complete driveshaft, it's probably be cheaper).
If the center pivot ball is ok, I'd just replace the u-joints. 20 bucks versus...what 200??150???
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-13-2005, 08:13 PM   #6
chevy lover
HMMMM Chevy
new u-joints......................$15.00ea.
new ball pivot....................$43.99
new drive shaft..................$189.99
To have my 4x4 back for the rest of the winter.........priceless
Mike
Old 12-13-2005, 08:19 PM   #7
wedgemon
wedgemon's Avatar
Let us know how the 465/205 works with the diesel. Real stump puller is my guess.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 12-13-2005, 08:32 PM   #8
chevy lover
HMMMM Chevy
even without the front axle. lots of pull but no get up and go. hope to change that come spring tho with new rears and gears.
Mike
